Upgrade to blasting cabinet
Jerry
We bought a HF blasting cabinet a few years ago and when new, work ok. Lately, the output of media just sucks. I have taken apart the suck tube, the air input and cleaned the gun but no improvement. I finally bought a new gun and what a difference. The new gun is like using a different piece of equipment. One swipe and stuff is gone.
So something in the old gun is causing problems, but I had already replaced the o ring, ceramic nozzle, and cleaned it multiple times. Perhaps if you have a cabinet that is having problems a new $50 gun off ebay will help.
Jerry
still needs a vacume to keep the dust down so you can see inside.
Banjo
Thanks for the tip Jerry. I have a blast cabinet from Tractor supply. It's gotta be about on par with an HF unit. Mine still seems ok, but I'll remember that if it starts to puke on me.
JodyFKerr
The first thing I do with Harbor freight sandblast guns is throw them away! I've never managed more than about 120 hours worth of use out of one.
Invest in a better gun with replaceable, easy to source, ceramic nozzles and you'll be happy for life. I normally get mine at Grainger, but local sandblasting shops / the internet is a great source.
J
Jerry
The new gun has carbon steel tips. I wonder how long they will last? At least they sent 3 with the gun.
Jerry
I've been using the same carbon tip in my Skat Blast cabinet now for 3 years, I use my bead blaster almost everyday at work.
PAUL161
This is what I use for a cabinet blaster. It's a Harbor Freight, I only use walnut shells in it most of the time, but on rare occasions, I use glass beads. I've had no problems with it so far. Not used every day, maybe a couple times a month. So for me and how little I use it, it was money well spent. It's 4 years old and still has the original gun. PJ
martx-5
We do a lot of sandblasting here at work. We have three automatic machines with four nozzles each, and about eight hand operated machines. We were a slave to ceramic nozzles and finally went over to boron carbide. At two to three times the cost, they are very expensive, but will probably last ten times as long. We won't use anything else now. If you are doing a lot of sand blasting, consider looking into boron carbide. Otherwise, the ceramics will work well enough.
That said, here is a link to show you you to determine how worn the nozzle is. Once it's bore get's 50% larger then new, it'll pass 2 1/2 times the air and abrasive. If your compressor can't keep up, then the pressure drops and productivity takes a nose dive. The same can happen inside the gun itself, so it's best to look and maybe take some initial measurements inside a new one (or a good working one) to compare to when the things go south. Also, oval shaped holes inside both the guns and nozzles are a good indication that there is a lot of wear.
https://www.surfacepreparation.com/when-blast-nozzle-worn
PAUL161
Art, Thanks for that bit of info. Quite informative and so easy to periodically check the nozzles. PJ
abarth69 Innocenti 1275 upgrade path Spridgets 1
S fuel pump upgrade Spridgets 0
P Suspension upgrade for a A40 Devon. British Motor Corp 0
S Sprite Fuel Pump Upgrade Austin Healey 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
petnatcar Fuel Line Upgrade Austin Healey 8
petnatcar Fuel Pump Upgrade Austin Healey 2
B 948cc Engine Upgrade Austin Healey 2
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
Guido36 LED Headlight Upgrade Austin Healey 1
M Tachometer not working following ignition upgrade Austin Healey 10
Lin New Forum Upgrade Question Austin Healey 8
M TR6 Alloy Wheel Upgrade Triumph 19
J General TR Cam shaft upgrade????? Triumph 3
roscoe 100 harmonic balancer upgrade? Austin Healey 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
Got_All_4 TR6 Heater upgrade Triumph 6
S TR4/4A Coil-over suspension upgrade Triumph 4
B Windscreen washer pump upgrade Austin Healey 10
Marvin Gruber 100/6 Brake Upgrade Austin Healey 5
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Keoke Latest Upgrade Austin Healey 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
V BJ8 Tacho upgrade Austin Healey 9
T What is needed for a 'big brake' upgrade; how well does it work? Spridgets 14
B Radiator upgrade Austin Healey 55
S LED Exterior Light Upgrade Spridgets 15
Rut TR4/4A Frame upgrade Triumph 2
TomMull General Tech Headlight upgrade Triumph 9
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
HealeyRick Brake Caliper Upgrade Austin Healey 120
O 57 100-6 Disk Brake Upgrade kit Austin Healey 9
S austin a40 somerset chassis swap/upgrade Restoration & Tools 2
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
RJS TR4/4A R200 Differential Upgrade Triumph 2
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
D Bumper Bracket Upgrade Spridgets 6
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
Michael Oritt Engine upgrade Racing 8
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
C Wedge TR8 Radiator upgrade Triumph 13
bobh TR6 TR6 Brake Upgrade Triumph 19
B seat belt upgrade complate ! MG 1
TonyPanchot Spitfire Carb Upgrade Spitfire Triumph 4
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
A XKE Series II Stromberg Carb Upgrade Jaguar 4
8 TR4/4A TR4A - Brakes Upgrade Triumph 13
