master cylinders
oxford
Hi everyone
I am trying to work out what size master cylinders to use on my late model BN4. The originals are 3/4" brake, 5/8" clutch. Can I use the same size on brake and clutch? Ie: 3/4 or should I go with original sizes?
Thanks
Matthew
ChrisBN4
At least if you have the original drum brakes, it won't work with the smaller brake cylinder 5/8. I would use the original sizes for both, clutch and brake.
Regards Christian
HealeyRick
Not much reason to deviate from original unless you've made other changes to the system like different sized wheel cylinders. MCs can be changed to affect pedal feel, but you run the risk of changing pedal travel and in extreme cases can end up having insufficient hydraulic fluid capacity to operate the system.
L TRW-Lucas Brand Master Cylinders Austin Healey 2
K TR2/3/3A Clutch Master Cylinders? Triumph 1
mctriumph TR2/3/3A Defective master cylinders Tr3 Triumph 13
Bayless Master cylinders questions Spridgets 7
Lin Girling Master Cylinders Austin Healey 5
F TR2/3/3A Master Cylinders Triumph 5
drooartz MGB Difference in clutch master cylinders? MG 4
jlaird Bugeye Master Cylinders Spridgets 2
CJD TR2/3/3A Early Lockheed Master Cylinders Triumph 24
R TR4/4A TR4 Master Cylinders Triumph 3
T TR4/4A Master cylinders - TR4A Triumph 0
Lukens Honing master and slave cylinders Triumph 8
Bayless Anglia master cylinders Other British Cars 2
mgedit Bench Bleeding Master and Slave Cylinders Triumph 5
tahoe healey threading on master cylinders Austin Healey 5
B Master Cylinders on early cars Spridgets 5
angelfj1 Moss Master Cylinders - The Recall Triumph 0
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
B New Master Cylinders Austin Healey 3
L Storing master cylinders Restoration & Tools 9
angelfj1 Warning - Moss Classic Gold Master Cylinders MG 0
angelfj1 Warning - Moss Classic Gold Master Cylinders TVR 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Spridgets 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Austin Healey 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Lotus 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Jaguar 0
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
B Replacing Clutch Master and Slave Cylinders Spridgets 35
mountainman Brake and Clutch Master Cylinders Triumph 12
mountainman TR 3 Brake & Clutch Master Cylinders Triumph 2
T TR6 Replacing TR6 clutch and master cylinders Triumph 2
KVH Why Resleeve Clutch or Braker Master Cylinders Triumph 11
Brosky Sleeving of Master Cylinders, who?? Triumph 22
Y Brake & Clutch Master Cylinders Triumph 1
S Master Cylinders Austin Healey 2
Taz Master cylinders Spridgets 10
TRJohn TR2/3/3A TR2 TR3 master cylinders Triumph 2
im_a_hypnotist dual master cylinders for disk brakes - parts avai Spridgets 2
John Loftus Quality Master Cylinders Austin Healey 5
L Removing Master Cylinder Without Paint Damage Austin Healey 27
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
