Storing master cylinders
lotuslover
I have a couple of spare unassembled master cylinders I'm not using. What the best way to store them so that the bores don't corrode?
Mickey Richaud
I'd spray them down with WD40 and put 'em in ziplock bags. The WD40 can easily be cleaned off when they're needed.
Platinum
BAH!!! WD-40 is a (W)ater (D)isplacement compound. Water AVID in real life.
Smear the bores of unassembled cylinders with <any> GREASE, fercryinoutloud.
*sheesh*
Bro, we gotta TALK. :devilgrin:
Platinum
Better'n WD-40!!!
Platinum
Best to use Girling's product made for use on assembly of brake hydraulics. But if you intend to store the cylinders before rebuilding, the main thing is to prevent rust/corrosion so any grease will do. Just be thorough at cleaning before rebuild.
jessebogan
Heh.. Bacon grease... What IS that I smell? A refreshing change from following a fryer oil diesel conversion.
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
F TR2/3/3A Storing painted parts Triumph 7
BoyRacer Rig for storing chassis on its side Austin Healey 8
Csarneson Storing a newly rebuilt engine Austin Healey 25
BN6_2197 Storing side screens in a BN6 Austin Healey 4
S TR2/3/3A Storing a tr3 hard top Triumph 3
P storing my midget for the winter Spridgets 6
trrdster2000 Storing, what mommy did't tell you Triumph 2
P Storing for Winter MG 4
T Storing Car for Winter Restoration & Tools 0
L Removing Master Cylinder Without Paint Damage Austin Healey 27
L TRW-Lucas Brand Master Cylinders Austin Healey 2
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
6 Master Cylinder Actuator rods Spridgets 2
6 Master Cylinder Install Spridgets 5
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
K TR2/3/3A Clutch Master Cylinders? Triumph 1
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
mctriumph TR2/3/3A Defective master cylinders Tr3 Triumph 13
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
R TR2/3/3A Master Cylinder Re-build Triumph 6
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
D TR2/3/3A sealing master cylinder pocket Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
Rob Glasgow Ant Ansted Master Mechanic Austin Healey 4
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
R TR2/3/3A Lockeed Master Cylinder Adapters Triumph 8
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
D Clutch Master Cylinder Leak Austin Healey 20
6 Master Cylinder Rebuild Help Please Spridgets 3
D BJ8 brake master cylinder question Austin Healey 6
