TR6 LED instrument conversion / Dimmer.
Gliderman8
Elliot why did you go with green bulbs? Got may dash all apart to remove heater motor. Wiring oil soaked from oil pressure gauge leaking. Anyway decided to convert bulbs while i have easy access to all gauges.
I'm thinking of going white and a bit concerned that they my be too bright. I like 72djm76dkm converting to a digital rheostat. Wonder where he got that done. Now not all LEDs are dimmable. Do you know if yours are? I also saw on the listing a cool white bulb and wonder if it's not as bright.
Green bulbs? I didn't use green bulbs. There is a green lens in the instrument back that makes the light appear green.
I really don't know if they are dimmable since my rheostat doesn't work. If you find any info on a digital conversion I'd like to see it.
Check your PM
Paul Fanning
I got my interior LED bulb kit from classiccarleds.co.uk which includes the appropriately coloured bulbs for each location. The colours match the colour filters in the gauges, which are left in place. The filters are essentially transparent to the coloured light anyway but it gives a very saturated result. Mine are definitely brighter than the incandescents but I bypassed the rheostat anyway and have no issues with it being too bright.
Paul
74 TR6
jeb_tr4
Considering switching to LED’s for my instrument panel. Can I just simply cut out the dimmer? Is there a nice replacement for the hole : ie: clock? Any considerations and thoughts appreciated.
Thanks,
Will
I put in an on/off switch and used the original knob.
Foura
I dumped the rheostat as it never worked reliably and with old incandescent bulbs it was always on full anyway. It fell apart when I took it out. I used the threaded part of the switch and made up a bracket to mount my new intermittent wiper switch. On the last day of our 5200 mile trip across Australia and back it rained non stop. The passenger became the intermittent wiper operator. I bought the kit from Retronics in the UK and I think that Revington is selling it also. I used the rheostat knob so it looks original.
Got_All_4
Took the tack out today and got my electric Dremel style tool out. Had a small fiber pad on a mandrel along with some high cut buffing compound and buffed the snout out of the blue lens inside the light fixture. also disassembled the tack because there was a chip on the black trim ring so had to repair it. Was surprised that where the bulb mounts and sticks through along side the tack frame is painted black inside. About a inch wide so I taped it off and painted the black chrome. Put it all back together and looks awesome. I think that black collar that goes around the perimeter of the glass has a lot to do with directing the lighting. Seems to have a steeper angle to one side and noticed a notch in it and on the frame of the tack. Put the two together and works perfectly now. Not 100% sure but I think the angled part was facing the left side of the tack blocking the light. The lens was not burnt at all.
Gliderman8
Strange that the inside was black. All of my Smiths gauges were white on the inside to reflect the light.
In any case, glad you got to the bottom of it.
bighealeysource LED Instrument Lights Austin Healey 12
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
B instrument led lamps Austin Healey 12
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
B TR6 LED Headlights Thouights? Triumph 14
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
Scotsman TR2/3/3A LED headlights Triumph 4
