Leaky Steering Box
My BJ8 is leaving a (larger than usual) oil spot on the flattened cardboard box that serves as a disposable drip pan and leak map. It appears to be leaking at the 'cover' (Moss# 667-835), where I know there is a shim pack and, possibly, a gasket. I know throwing Penrite or STP in there might lessen the leak, but I'm wondering why the box would start leaking suddenly at a place that doesn't experience any movement or wear?
Thoughts?
Bobbydsport
Possible temperature change, becoming much colder than usual causing the gasket to shrink up a bit ? A friend of mine from Calf. said they have been experiencing some much colder weather in certain parts of the state.
Bobbyd
Keoke
Well Bob:
The adjustment screw in the top does cause some stress to be put on the lid when the steering is used.
As Bobbyd suggested this colder en "L" weather we are having may also contribute to the problem
You might just tighten up on the fasteners a bit and see if it will stop leaking.
steveg
Thoughts?
If snugging up the bolts doesn't fix it or if you have to replace the gasket, suggest use of Penrite or John Deere Corn Head grease instead of gear oil, as they'll be less likely to leak. STP not good as it has no lubricating properties.
blueskies
I second that John Deere Corn Head grease suggestion. The great thing is that one can buy it at the John Deere dealer, if one has a JD dealer close by. Getting it into the steering box can be a bit of an issue, as it is quite thick. It comes in a grease tube, so one method is to put one of those long pointy tips on the grease gun and inject it into the steering box through the fill hole. Once it settles, inject a little more.
drambuie
. Maybe warming it up in the wife's oven a bit may help a little ... Just as long as she doesn't serve it up for your dinner! Just kidding about the suggestion:smile:
blueskies
Hmmm, you might have something there; it is called Corn Head Grease. I wonder if it contains corn? And what's a corn head? No idea.
steveg
Scuderia Silva has a good point: when you've got the steering box filled, operate the steering wheel lock-to-lock a couple of times and you'll see the box is only half full.
https://youtu.be/4UwsfMPWuGg
blueskies
Google it and see. :smile:
Not what I was expecting! Google has this:
images
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
S TR4/4A Leaky Overdrive Triumph 16
M Leaky Fuel Pump and Weak Performance Spridgets 14
C TR6 Leaky brake caliper Triumph 6
Rut TR4/4A Leaky heater valve Triumph 3
M Leaky carbs... Austin Healey 5
Bob Claffie MGB Leaky gearbox MG 2
R Leaky carb Austin Healey 6
Zitch Leaky SUs where to buy rebuild Triumph 22
Westfield_XI A leaky dipstick Spridgets 5
M Leaky oil pan... again Triumph 16
tri_carb_healey leaky lead carb Austin Healey 6
L Simple fix for leaky tappet cover Austin Healey 0
V Leaky heater valve? Spridgets 47
60TR3A Leaky Oil Pressure Gauge Triumph 14
MCNX_BFF Cracked and leaky Triumph 20
W Leaky Windscreen Triumph 3
K Leaky roof Jaguar 22
C Leaky exhaust from manifold Spridgets 3
bthompson More leaky axles... Spridgets 6
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
N MGB MGB with Leaky brakes? MG 3
Brosky Leaky voltage stabilizer Triumph 7
B Leaky SUs on E-Type Jaguar 2
Stewart Leaky transmission oil drain plug MG 3
C Leaky Carbs Triumph 16
MTribe leaky fuel pump - ideas? Triumph 6
healeyboz Leaky engine poll Spridgets 31
MadRiver Z3 leaky top Other Cars 2
MadRiver Leaky BT7 Overdrive Austin Healey 2
Adam58 Leaky TiDi [rhymes w/ tiki] transmission MG 25
S Leaky valve cover gasket Triumph 5
delisaj Leaky fuel pump? Triumph 7
19_again Leaky wheel cylinder MG 8
SCguy TR6 Leaky TR6 Triumph 10
mrv8q TR6 TR6 Leaky Carbs Triumph 10
B Leaky Freeze Plug Austin Healey 33
C Leaky carbs. Triumph 6
jjbunn T-Series Leaky Clutch Slave Removal MG 20
Sarastro Leaky rear hub seal Spridgets 10
Woodie leaky wiper posts Spridgets 3
W Leaky clutch cylinder Triumph 2
L Leaky Car MG 2
jsneddon TR2/3/3A Leaky SUs - Late TR3A Triumph 3
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Johnny Leaky side shifter Austin Healey 8
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
G leaky brake master cyl MG 4
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
