Julian, if the fork moves the same distance at the fork pushrod at each "stab" on the pedal, the clutch plate may be rusted to the flywheel... Be *SURE* the hydraulics are moving the rod the same distance from the first push to the third one... if that's so you need to break the "rust bond" between the pressure plate and the flywheel. First go should be to put the car on a level surface... With someone in the drivers' seat and the clutch depressed, the box in second or third gear, a "second crew" should shove the car forward and backward untill it "ThUnKs" and rolls freely. This is an indication the rusty pressure plate has released from the rusty driven plate.
An alternate method is to warm the engine to "normal" temp, turn it off, put the tranny into first and with the clutch depressed, try to start the engine. An OBVIOUS caveat is to be sure there's NOTHING in front of the car when attempting this maneuver! /ubbthreads/images/graemlins/grin.gif
