Leaky Freeze Plug
Blonde Healey Girl
Our 60' BT7 has a weeping freeze plug. Naturally it's on the back and up against the firewall, only visible with the help of a mirror. It's the upper one closest to the intake manifold. What are my chances of cleaning it and filling it with a JB Weld type product? The tranny tunnel offers a little working room in terms of trying to replace it. Are there any replacement plugs that you don't have to hammer in? Very confined work area!!!Thanks!
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
There sure are. See attached pic. Just stick it in the hole & tighten the nut to expand it. Available at many auto parts places. Although supposedly temporary, some folks have been known to get by for years.
Randy Harris
Hey, you think that's a confined space to work, try replacing the upper plugs behind the carbs and manifold. Major PITA. You definitely can change out that rear plug using access from the tunnel. Or, I guess you could try that gizmo that Dave recommends. But I'd want to know what's going on with the engine that caused the plug to fail. If one is gone chances are the others are also in various state of decay.
I had a very leaky plug, in the worst possible position, that turned out to be the result of a poor installation by a PO, rather than corrosion. Turns out I only needed to replace the one plug. Perhaps you'll be lucky like that too.
Randy '66 BJ8
Ed Kaler
B.H.G.:
Dave is quite correct. /ubbthreads/images/graemlins/iagree.gif It is a VERY common problem!! /ubbthreads/images/graemlins/eek.gif
A lot of us carry a couple in the boot "just in case"!! /ubbthreads/images/graemlins/nonono.gif
Ed
Dave Russell
Yoda - R.I.P
Hi TH,
I have no idea what size. My engine has three different sizes, 1.620", 1.312", & 1.180", so I keep several "in the boot". Your best bet is to get a caliper on some of yours & get measurements. Or maybe someone more knowledgeable on the Sixes knows.
A given plug covers quite a size range so they don't have to be real exact. For example, the one shown in the pic will go from 1.135" to 1.230" & nicely covers my 1.180" plug.
Keoke
[ QUOTE ]
Dave, what is the size of the plug? I'd like to carry one in the boot.
[/ QUOTE ]
OH !! TH, you will have to get "TWO" as the parts book says : "Core Plugs Large and Small" so you will need one of each.--Keoke- /ubbthreads/images/graemlins/devilgrin.gif
AUSMHLY
Hi TH,
Good idea to carry one of each as a spare/back-up!
Please post what the two sizes you get and where you got them. I too would like to pick up set.
I've been following your updates about your car.
Learning a lot. Thanks for sharing and best of luck.
Cheers, Roger
Randy Harris
Roger - as you know, I was going to do an complete coreplugectomy last month but found that I didn't really need to do that. So I have a bag full of core plugs (both sizes) that I never got around to sending back to the vendor. You're welcome to whatever you would like.
Randy '66 BJ8
AUSMHLY
Hi Randy,
I was thinking more a line the lines of one of each of the rubber ones. Thinking that they may be easyer to install in an emergency situation?
Thoughts on rubber vs metal, folks, for emergency?
Roger
Keoke
Hi Roger, It really does not make any difference which you use if it is for emergency use only. For a more permanent use of the rubber one I might change the Bolt/Nut to SS. OTOH, there is an all metal one which is a real design wonder. It is made of brass I think, installs similar to the rubber one but is of a more permanent fixture. I looked for it in my files but could not locate it again. A bit of searching on the Internet should turn it up, It certainly is worth the effort.---Fwiw---Keoke
Dave Russell
Yoda - R.I.P
[ QUOTE ]
OTOH, there is an all metal one which is a real design wonder. It is made of brass I think, installs similar to the rubber one but is of a more permanent fixture. -Keoke
[/ QUOTE ]
The metal plugs are available in several sizes as shown below.
I really believe that the rubber plugs are better for emergency use. The metal plugs require a very clean & smooth seating surface & have little expansion capability. Hard to correctly install in a roadside emergency.
I once installed the metal plugs in a Chrysler Hemi build up. Perfectly clean & true seating surfaces, ideal access conditions. They lasted a very long time & never gave any trouble. Probably better than the original stock type plugs.
The rubber plugs cover a larger size mismatch & seal much better on the rough, dirty surfaces that are likely to be encountered in an emergency.
https://www.dormanproducts.com
Dorman catalog listings:
Quick-Seal Copper;
1 1/4" - #024-080
1 1/2" - #02482 or #568-009
1 5/8" - #02483 or #568-010
1 3/4" - #568-011
Quick-Seal Rubber;
3/4" to 7/8" - #02608
7/8" to 1" - #02609
1" to 1 1/8" - # 02600
1 1/4" to 1 3/8" - #02601
1 3/8" to 1 1/2" - #02602
1 1/2" to 1 5/8" - #02603
1 5/8" to 1 3/4" - #02604
1 3/4" to 1 7/8" - #02605
1 7/8" to 2" - #02606
2" to 2 1/8" - #02607
Keoke
No Dave, I thought the one I saw was Dorman too but that is not the case. The one I saw is similar but comes in random sizes not indexed to specific cars and includes a very detailed color picture and an extensive presentation on how it works. I will run across it again I am sure.--Keoke
OH! with the Dorman plugs smearing them with "Locktite" Ultra Grey prior to installation, I think its Type 555, not the Permatex stuff available in most of the discount part houses, will seal them up tight.
Keoke
/ubbthreads/images/graemlins/blush.gif Wot!! am I doing over there reading about MG's ?--- /ubbthreads/images/graemlins/lol.gif Yeah I thought that it was Dorman. Use the sealer and they work a treat.--Thanks--- Keoke-- /ubbthreads/images/graemlins/thumbsup.gif
I've used Dormans on my XK140 years ago and was impressed at how easy it was. Didn't use any seal or locktite and had no problems. I did over tighten one and distroyed it. I'm not sure the amount of torque that should have been used but I exceeded it. It was fun getting the remains out.
bighly
So what part numbers are needed in my bag of road spares?
Keoke
Yep TH, The jags eat their core plugs alive up under the manifolds. So we use the repair technique until its justified to pull everything apart and replace with new plugs. Sure not going to do all that work for one leaky plug.---Keoke- /ubbthreads/images/graemlins/laugh.gif
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
I don't know what sizes your engine uses. Two different sizes I believe. Maybe someone who knows will reply. Could you just measure a couple in your engine?
Keoke
[ QUOTE ]
[/ QUOTE ]
--The core plug sizes fitted to the 3000 engines are: 1 1/4", 1 5/16", 1 5/8" and 1 3/4"----Fwiw---Keoke
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
S TR4/4A Leaky Overdrive Triumph 16
M Leaky Fuel Pump and Weak Performance Spridgets 14
C TR6 Leaky brake caliper Triumph 6
Rut TR4/4A Leaky heater valve Triumph 3
M Leaky carbs... Austin Healey 5
Bob_Spidell Leaky Steering Box Austin Healey 11
Bob Claffie MGB Leaky gearbox MG 2
R Leaky carb Austin Healey 6
Zitch Leaky SUs where to buy rebuild Triumph 22
Westfield_XI A leaky dipstick Spridgets 5
M Leaky oil pan... again Triumph 16
tri_carb_healey leaky lead carb Austin Healey 6
L Simple fix for leaky tappet cover Austin Healey 0
V Leaky heater valve? Spridgets 47
60TR3A Leaky Oil Pressure Gauge Triumph 14
MCNX_BFF Cracked and leaky Triumph 20
W Leaky Windscreen Triumph 3
K Leaky roof Jaguar 22
C Leaky exhaust from manifold Spridgets 3
bthompson More leaky axles... Spridgets 6
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
N MGB MGB with Leaky brakes? MG 3
Brosky Leaky voltage stabilizer Triumph 7
B Leaky SUs on E-Type Jaguar 2
Stewart Leaky transmission oil drain plug MG 3
C Leaky Carbs Triumph 16
MTribe leaky fuel pump - ideas? Triumph 6
healeyboz Leaky engine poll Spridgets 31
MadRiver Z3 leaky top Other Cars 2
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
MadRiver Leaky BT7 Overdrive Austin Healey 2
Adam58 Leaky TiDi [rhymes w/ tiki] transmission MG 25
S Leaky valve cover gasket Triumph 5
delisaj Leaky fuel pump? Triumph 7
19_again Leaky wheel cylinder MG 8
SCguy TR6 Leaky TR6 Triumph 10
mrv8q TR6 TR6 Leaky Carbs Triumph 10
C Leaky carbs. Triumph 6
jjbunn T-Series Leaky Clutch Slave Removal MG 20
Sarastro Leaky rear hub seal Spridgets 10
Woodie leaky wiper posts Spridgets 3
W Leaky clutch cylinder Triumph 2
L Leaky Car MG 2
jsneddon TR2/3/3A Leaky SUs - Late TR3A Triumph 3
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Johnny Leaky side shifter Austin Healey 8
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
G leaky brake master cyl MG 4
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
