Leaky carbs...
matt78
Hello.
Concern regarding my 100/4 carbs : I recently bought the car, with the information that the carbs had been completely overhauled - some of the gaskets I can see actually seem to be new. The car starts and runs very nicely.
During several electrical checks of the wiring, I had to switch the contact ON, causing the fuel pump to run (engine not running). I then noticed that some fuel leaks appeared at the bottom of the jets (still not sure of the exact location of the leaks' source).
Incidentally, the choke was "on", so my questions are :
- is this normal ? I guess it is not, but as the choke was engaged, maybe it could have worsen the situation ?
- if this needs to be corrected as I think it should, do you think that it would be useful to - again - overhaul the carbs by using the full SU kit, or is there any chance that the leaks might be caused by worn-out "mechanical" parts (jet, bores...) ?
Thank you in advance for your replies (silly question maybe, but I don't know these cars, and don't want to replace parts that don't deserve it).
Regards,
Matt
blueskies
Those likely are H4 carburetors. If so, they have two seals located in the lower part of the carb that go around the jet - one above and one below the small spring that fits around the jet. There also is a larger rubber seal - O ring type - directly above the big nut just above the jet adjustment nut. You might begin by tightening that big nut, taking care not to turn the smaller nut below it that adjusts the jets. If that does not fix the leak, it might need the smaller seals mentioned above.
My acquaintance with H4 carbs is recent and I do not claim to be an expert on them. I also need a rebuild kit for my H4 carbs.
BigGreen
To find out the type of carburettor, see the SU website https://sucarb.co.uk/
Lots of pictures and instructions
Succes
bob hughes
Just throwing this into the mix - the floats are there to prevent fuel from entering into the jets unless there is a draw on the fuel through the carbs - i.e. the engine turning over. Could it be that the floats need adjustment ?
:cheers:
Bob
EV2239
The floats and their needle jets are set so fuel is in the jet and a little below the bridge in the main throttle body.
This means that the jet housing below has fuel in it which may leak. The jet is lowered a 1/4" when the choke is pulled and it slides up and down in compressed cork gaskets that are rarely completely leak free. Therefore the lower part of the carburettor may well be wet, but not dripping. Experience alone tells you when it's time to change the cork seals.
The Burlen Fuels/SU website will have exploded diagrams to assist in understanding the vagaries of these carburettors.
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
C Leaky Carbs Triumph 16
mrv8q TR6 TR6 Leaky Carbs Triumph 10
C Leaky carbs. Triumph 6
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
S TR4/4A Leaky Overdrive Triumph 16
M Leaky Fuel Pump and Weak Performance Spridgets 14
C TR6 Leaky brake caliper Triumph 6
Rut TR4/4A Leaky heater valve Triumph 3
Bob_Spidell Leaky Steering Box Austin Healey 11
Bob Claffie MGB Leaky gearbox MG 2
R Leaky carb Austin Healey 6
Zitch Leaky SUs where to buy rebuild Triumph 22
Westfield_XI A leaky dipstick Spridgets 5
M Leaky oil pan... again Triumph 16
tri_carb_healey leaky lead carb Austin Healey 6
L Simple fix for leaky tappet cover Austin Healey 0
V Leaky heater valve? Spridgets 47
60TR3A Leaky Oil Pressure Gauge Triumph 14
MCNX_BFF Cracked and leaky Triumph 20
W Leaky Windscreen Triumph 3
K Leaky roof Jaguar 22
C Leaky exhaust from manifold Spridgets 3
bthompson More leaky axles... Spridgets 6
N MGB MGB with Leaky brakes? MG 3
Brosky Leaky voltage stabilizer Triumph 7
B Leaky SUs on E-Type Jaguar 2
Stewart Leaky transmission oil drain plug MG 3
MTribe leaky fuel pump - ideas? Triumph 6
healeyboz Leaky engine poll Spridgets 31
MadRiver Z3 leaky top Other Cars 2
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
MadRiver Leaky BT7 Overdrive Austin Healey 2
Adam58 Leaky TiDi [rhymes w/ tiki] transmission MG 25
S Leaky valve cover gasket Triumph 5
delisaj Leaky fuel pump? Triumph 7
19_again Leaky wheel cylinder MG 8
SCguy TR6 Leaky TR6 Triumph 10
B Leaky Freeze Plug Austin Healey 33
jjbunn T-Series Leaky Clutch Slave Removal MG 20
Sarastro Leaky rear hub seal Spridgets 10
Woodie leaky wiper posts Spridgets 3
W Leaky clutch cylinder Triumph 2
L Leaky Car MG 2
jsneddon TR2/3/3A Leaky SUs - Late TR3A Triumph 3
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Johnny Leaky side shifter Austin Healey 8
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
G leaky brake master cyl MG 4
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
