TR4/4A Inside Windscreen Capping
ghawk16
So I bought the black plastic/hard vinyl/whatever it is TR6 windscreen capping set that goes on the inside of a freshly painted windscreen. It is four pieces...two sides, one center upper and one center lower. Well, while it's 100 degrees out here in NorCal I'm going to work on this inside my apartment. But my question is...do the middle pieces overlap the side pieces on the upper and lower left and right portions or do the side pieces overlap the center pieces. I can't seem to see it in any of my old pictures. I hope that question makes sense. Thanks.
charleyf
I am not familiar with the TR6 set up ---But on the TR4 vinyl upholstery which is glued on it is vertical first followed by the horizontal strips.
Charley
G
ghawk16
Charley
That's what I needed to know! Only reason I mentioned TR6, is they don't sell the set for the TR4 but since the windshields are the same you can use the TR6's. This is going on my TR4. Thanks!
charleyf
Gary,
Glad to help. I suspect that I made my own using the old ones for the pattern. I also recall checking which piece went on first.
Charley
Geo Hahn
Charlie's got it - but in case it helps, here are some photos of the corner details on my TR4 with its original trim (lower right, upper left, upper right and lower left):
G
ghawk16
Excellent pictures! Thank you. Funny to see that even on the original that the top right comes in further than the top left so they aren't even. But this is a perfect reference to see how far to cut the trim if need be.
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
T TR2/3/3A rings inside bevel Triumph 2
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D What's inside the gas tank?? Spridgets 13
C Inside Door Handle Austin Healey 5
J Flaking Paint Inside Differential Austin Healey 6
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
FlyingCat Spitfire Inside door handle Triumph 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
L 100 ID plate inside cockpit Austin Healey 10
T Frame: Inside Treatment? Austin Healey 8
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 11
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 4
RickB MGB Rain water getting inside behind dash MG 17
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
M BT7 Inside Threshold Plates Austin Healey 1
B Replacement of Small Black Wire inside Distributor Austin Healey 15
Jim_Gruber Painting inside a BE Boot Spridgets 8
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
J Outside door handle opens but not inside Austin Healey 2
BoyRacer thermal barrier on inside of firewall Austin Healey 6
D Inside the frame rails Austin Healey 14
A TR2/3/3A TR-3A post 60K inside trunk latch photo Triumph 4
K Rough patch inside bore of SU? Triumph 2
P Odometer Finger Prints inside glass Triumph 9
T TR2/3/3A Peak inside the TR3 sill Triumph 8
R fuel tank cap., anything inside displacing volume? Spridgets 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
H inside of wings question Austin Healey 7
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
wangdango inside of body panels? Austin Healey 10
TraceZ Our sprite is ALIVE - video inside!! Spridgets 7
M Help - inside my distributor Austin Healey 5
H filters inside of BJ air cleaner? Austin Healey 24
AUSMHLY Inside the car Blind Spot Mirror - MacGyvers back! Austin Healey 61
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
I Source for ribbed material for inside bugeye door? Spridgets 5
M Spitfire RARE BL Spitfire parts catalog see inside Triumph 0
T TR2/3/3A TR3 inside door linkage Triumph 8
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
aeronca65t inside pass Spridgets 9
livinginthepast BE bodywork question - inside/fwd hood brace[?] Spridgets 17
T TR2/3/3A TR3 diff color -inside Triumph 27
