Swiss Toni
Member
Hi Chaps
First post after lurking in the shadows.....
I'm hoping for some insight on setting up ignition timing on my B7T works rally rep which I purchased about a month ago. 1st classic car and really enjoying it!
Its got got fairly serious engine on triple webers and just going through things.
Today was ignition day, new wires & plug caps, coil, cap, rotor, points, condenser, plugs, basically the works.
I set the idle when warm at about 800 to 900 rpm but I can't get the timing below 12 deg. The shop manual says 6 degrees is what it should be. Then distributor is backed of as far as it will go (the advance housing is resting against the steering column and the micrometer is set at full retard.
When rpm is increased it advances to 36 degrees which is in spec.
Took it out for a road test and runs better than ever, especially at higher rpm's.
Am I missing something?
Cheers
Cheers
