rjc157
Been having trouble getting my rebuilt tach to work properly was told it could be the switch so I bought a nos switch for my bj8 negative ground it was converted yrs ago now trying to retrace steps in the back of the switch there are only 2 spade connectors at the #2 post and I have 3 connectors I know one is the fuel pump one goes to the fuse box and the third one is supposed to run through the loop to the dist what do I gang together .From what I see on the wiring diagram the fuel pump is not connected to the switch what do I see that's wrong ,I know this is stupid but on a neg ground car doesn't the switch wire go to the positive side of the coil and then there is a wire going from the neg side of the coil to the dist hope this makes some sense its driving me crazy
