TR2/3/3A Intermittent ignition switch problem
Crankshaft
I drove my car last Saturday and had several occasions to shut off and restart throughout the day with not a sign of a problem. Got back into the car Sunday morning and there was no sign of life when I turned the key. Did not touch the car until yesterday when I went into the garage to see what kind of problem might be causing the difficulty. As I might have figured, the switch and all else has been working fine since. I've not been able to find any loose connections etc. My question, is the switch something that I can get inside of to clean or service in some other way?
I'm usually reluctant to take the car out not knowing if and when the same monster might attack again.
Any suggestions?
TR3driver
Great Pumpkin - R.I.P
Just a thought : Did you try the headlights when nothing worked from the key?
Not sure if they are all the same, but my ignition switch was held together with two rivets. Pretty easy to drill them out, clean and lube the switch, then reassemble using two small bolts & nuts (10-32 IIRC, but might have been smaller). The bolts I had were kind of long, so I cut them to length with a Dremel & cutoff wheel after installation.
Jerry
I have new inserts to the ignition switch and both behave just like yours. But, in my case if you keep switching back and forth, it eventually starts. I think the new insert is too loose in the original case. One of mine is in a TR3 and the other is in an old mini.
Crankshaft
Crankshaft
Thanks guys. I will probably pull the switch out and give it a shot. I might get a new switch as a back-up just in case (if you know what I mean).
Thanks again
TFB
Thanks again
You could also use a short piece of wire with alligator clips as a backup since the terminals are big and exposed on the back of the switch.
Tom
trrdster2000
OR! Keep that same alligator clip wire and run it from the plus side of the battery to the plus side of the coil. I keep one in the Roadster at all times, it has the screw in terminals of brass on the switch and it will oxidize once in a while and start to skip like crazy. Not a lot of fun on the side of the road wire brushing the wire ends.
Wayne
CJD
The original switch is held by a nut that has solder dabbed on it. You can heat the solder, remove the nut, and the switch guts come out. Easy at that point to clean and reassemble. The nut is an adjustment for the contacts, so it doesn't screw down tightly...
If you have to remove the rivets, they can be replaced with screws.
Crankshaft
Crankshaft
These "hot wire" ideas remind me of my teen years and my older brothers' cars.
Thanks,
charleyf
Thanks,
Or as one Lady told me of her TR3 in her teen years. " I could use a foil gum wrapper to hot wire the car."
Charley
TR3driver
Tom
If you run it up to the tail light terminal on the light switch, the light switch will double as an ignition switch. I've been known to drive for several weeks that way, until I could find the key (or make a new one).
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Popeye TR4/4A Transmission noise - intermittent Triumph 22
B Intermittent Loss of Electric Power Austin Healey 18
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
