Trevor Triumph
The under bonnet solenoid on the 66 Spit will start the car with the ignition- key switch- on. The car will not start using the key in the ignition switch. When twisting the key in the ignition switch inside the car there is a clicking sound apparently from the solenoid. Does that sound like a switch problem or solenoid?
Seems a bit dangerous to have to get out of the car to start it at some intersection with a big truck bearing down.
T.T.
T.T.
