Ignition Switch and key Cylinder comes apart!
BugeyeNJ58
So, I turned off the ignition, went to pull the key out and the tumbler comes out about 1/2 way and stops. I disconnected the 4 wires and took the whole assembly into the garage.
After some research on this forum, I got the tumbler all the way out and slid off the knob and case. There's a bakelite sleeve inside the tumbler tunnel and that's what keeps the tumbler in place.
I just used J&B weld to glue the broken part of bakelite back into position. Hopefully in a few hours, when I put it back together. I'll be good to go.
Don't really want to buy a replacement, don't want to spend the money and I can't imagine it will last for over 50 yrs. like the original. Come to think of it, I'm not going to last another 50 years!
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
S TR4/4A Ignition switch key position Triumph 2
B T-Series Ignition key switch help ! MG 7
angelfj1 TR2/3/3A TR3A Ignition Switch - new lock/key Triumph 5
G ignition key/lock switch question Spridgets 0
G Removing ignition key/lock switch? Spridgets 5
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
P TR2/3/3A ignition switch smoking Triumph 12
C TR6 Ignition Switch for 1972 TR6 Triumph 1
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
longbridgehealey Bugeye ignition switch Spridgets 4
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
L TR6 1974 Tr6 ignition switch Triumph 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
J ignition switch, On but no starter at all times British Motor Corp 2
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
S BJ8 Ignition switch? Austin Healey 7
AngliaGT Ignition switch/Wiring Diagrahm..... Spridgets 0
AngliaGT Midget MKIII Ignition Switch Spridgets 0
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
rjc157 ignition switch Austin Healey 5
RedTR3 TR2/3/3A Ignition Switch Triumph 4
Gliderman8 TR6 Installing new ignition switch Triumph 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
longbridgehealey New Bugeye ignition switch question Spridgets 10
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
G T-Series Ignition switch MG 10
B ignition switch Spridgets 5
M TR4/4A TR4A Ignition Switch Circuit Triumph 3
G T-Series Tachometer and ignition switch MG 16
T Ignition switch Triumph 6
D T-Series Access to ignition switch '68 MGB MG 9
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
