TR2/3/3A Ignition Switch
RedTR3
Over the last few months I have been replacing many of the old electrical components on the TR3 in order to prevent surprise failures. Now I come to the old 50+ year old ignition switch. Are these old units prone to failure and is it worth replacing in order to be safe? I do know that the new units have modern spade lug connections which may be more secure than the old screw connections.
Thanks, Tim
trglory
Actually, the original part with screw type connections may be a bit more reliable. Clean the back side up with a wire brush, wipe it down with an oily rag and it sould be good for another 50 years.
CJD
The only thing that can go wrong is if the bakelite cracks. But that is most likely from being mis-handled rather than through normal operation.
If you want to take it apart, the nut on the back is tacked with solder. You have to heat it with an iron before you unscrew it. The nut is actually an adjustment, so don't just tighten it back down on reassembly. It gets tightened just enough to allow normal operation with the lock cylinder in place...and then tack it with solder to prevent it from unscrewing.
6TTR3A
I agree with Joe, the screw type are virtually bulletproof. It tends to get a little busy on the screw connectors if you tend to use them for accessories, so I solder multiple spades onto the screws.
Frank
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
P TR2/3/3A ignition switch smoking Triumph 12
C TR6 Ignition Switch for 1972 TR6 Triumph 1
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
longbridgehealey Bugeye ignition switch Spridgets 4
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
L TR6 1974 Tr6 ignition switch Triumph 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
S TR4/4A Ignition switch key position Triumph 2
J ignition switch, On but no starter at all times British Motor Corp 2
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
S BJ8 Ignition switch? Austin Healey 7
AngliaGT Ignition switch/Wiring Diagrahm..... Spridgets 0
AngliaGT Midget MKIII Ignition Switch Spridgets 0
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
rjc157 ignition switch Austin Healey 5
Gliderman8 TR6 Installing new ignition switch Triumph 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
longbridgehealey New Bugeye ignition switch question Spridgets 10
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
G T-Series Ignition switch MG 10
B ignition switch Spridgets 5
M TR4/4A TR4A Ignition Switch Circuit Triumph 3
G T-Series Tachometer and ignition switch MG 16
T Ignition switch Triumph 6
D T-Series Access to ignition switch '68 MGB MG 9
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
V Removing ignition switch assembly. Spridgets 2
BugeyeNJ58 Ignition Switch and key Cylinder comes apart! Spridgets 0
72_TR6_Oceanside Ignition switch wiring order help Triumph 16
O TR6 1971 TR6 Ignition Switch Swap Triumph 1
TulsaFred Bugeye ignition combination switch Spridgets 11
