BJ8 Ignition switch?
Scot
Guys,
Went out to start my BJ8 today and first twist of the key got the red ignition light and fuel pump ticking as always then it died quickly. Further attempts only got just a faint clunking sound and a small flicker of the fuel gauge needle now nothing at all when I try. Battery is fully charged and all ignition connections look tight. Could this possibly be a switch problem or something else? Any and all comment appreciated!
GregW
Platinum
You might want to check the battery switch in the trunk. Use a jumper cable to bypass it.
Guys,
How do you know your battery is fully charged? How old is it? Do you keep it on a conditioner when you don't drive it often? If you check with a voltmeter, an almost-dead battery might still show close to 13V, but won't be able to turn the engine over (the faint clunk you heard is probably the solenoid making contact). To really check a battery, you need a load tester (less than $100, and worth it if you maintain several cars). Try jumping the battery, being mindful of your ground orientation.
roscoe
Do the 6 cylinder cars have the big rubber button on the starter solenoid the way the 100's do?
roscoe
We'l,l then you could push that and it would bypass the starter button. Be careful and make sure it is in neutral if you do that. Don't want it exiting the garage and running you over if it starts.
Should qualify my answer: Original and some aftermarket solenoids have the push button; there are aftermarket solenoids that look nothing like the originals and don't have a push button (but they are cheaper).
S
Scot
Thanks for all the input guys! Bob was correct it was the battery but since I have never replaced one in a Healey I never knew the symtoms of a bad one. It was testing ok on a voltmeter and showed green on my battery tender but had no cold cranking amps left! New battery installed and problem solved.
I will say keeping the battery on a tender greatly extended the life of the old one though! My next purchase is a load tester as advised! Thanks to all again!
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
B Healey Bj8 [1964] ignition switch Austin Healey 8
S Wiring connections for electronic ignition BJ8? Austin Healey 3
F BJ8 Column Ignition Austin Healey 8
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
memphis BJ8 - Leave ignition key on? Austin Healey 5
J ignition key turning, BJ8 Austin Healey 5
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
