Healey Bj8 [1964] ignition switch
bobsharel
Can anyone help with deciphering the connectors on the back of the Healey ignition switch? There are six connectors (3 of which are doubled), leaving one single, The single has a white wire with red stripe, 2 white wires on the next doubled connector going counter clockwise as you look at the back of the switch, one brown wir on the next double connector (again going counter clockwise) and no wires on the final double connector.
I would like to know which connector I should use on the switch for an accessory function. Any ideas? The wiring diagram in the Haynes manual is pretty obscure.
Thanks in advance
Keoke
Bob there are only three positions on the switch: OFF,RUN and Start. As a general rule White wires are Switched power on.---Fwiw---Keoke
Keoke
DearTH, Just put a small bypass fuse around the open ground circuit and you can have der clock too. Or get an eight day wind up and mount it in the chubby box door---Keoke /ubbthreads/images/graemlins/laugh.gif
That would mean I'd get to drive once every eight days.
Actually I was thinking of putting it where the radio speaker goes along with an ammeter. I saw someone with that on this sight. Smith clock is easy. Smith ammeter not so easy.
Getting back to bobsherel...
When you turn the key how many stops do you have? My 64 phase one has only off on and starter. If you have extra posts, do you have an extra stop?
GregW
Platinum
Hi Bob,
As Keoke said, the white wire is switched power. The brown is always hot(except when trunk switch is off). The white/red wire makes the starter do it's thing. The wires at the ignition switch are not fused.
B
bobsharel
Hi Tahoe Healey:
The ignition switch has two stops in the clockwise direction - on and start. However, have you tried turning it COUNTER clockwise from the vertical (key insertion) position. I have a stop there as well that I assume is an accessory position. Not sure how that relates to the terminals on the switch - that's my problem as all radios/CD players etc available now have a wire for power and a wire for accessory. Worst case I can wire the two into the fuse box and bypass the 'accessory' issue (which, as have already stated I'm currently - no pun intended - in the dark about.
Thanks for your response and would appreciate any further input.
Bob
GregW
Platinum
Hi Bob,
If it’s a radio you’re installing, my question would be is your car still positive ground?
Keoke
Hi Bob, To the best of my knowledge the standard BJ8 ignition switch does not have a stop in the reverse direction. If yours does a simple light bulb test should tell you if a terminal on the switch is hot when the switch is in that position other than the brown wired one.If so it could be used for an accessory. However there is a wire behind the dash for connecting a radio if required.---Fwiw---Keoke
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
H Tourist Trophy Exhaust on Healey Bj8 Austin Healey 2
J Healey BJ8 anti roll bar bushes Austin Healey 2
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
R Healey BJ8 misfire Austin Healey 5
P Distributor and coil BMW in my Austin Healey BJ8 Austin Healey 10
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
S austin healey bj8 gearbox Austin Healey 3
davidb Austin Healey BJ8 dash pad removal Austin Healey 6
davidb Austin healey BJ8 - convertible top alignment Austin Healey 9
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
R healey bj8 Austin Healey 1
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
