Healey BJ8 misfire
rogermrm
Any ideas out there - all appreciated: Healey 3000 misfires badly at startup and when warm will run for 15 minutes ok then misfire or sometimes stalls when driving or at idle.
Upgrades to try and correct:- New electronic ignition fitted to old distributor, new/coil/leads/plugs, head completely overhauled, compression good 160 to 170 psi, new fuel tank/pump (Pump clicks away then stops when pressure is up) and filter, carbies have done approx 2000 miles since overhaul, new radiator.
the 'experts' have tuned it and I have tuned it - no difference.
Twin SU HD8 carbs.
Cheers, Roger.
Read more: https://healey.hyperboards.com/action/view_topic/topic_id/4722/post_id/21086#21086#ixzz3lVP3RvPI
DerekJ
Have you tried adjusting the advance/retard.? It has probably nothing to do with carbs so you may have wasted $1,100. Remember - 90% of carburettor 'problems' are electrical.
RAC68
Hi Roger,
I just thought I would come out of left field and suggest something that can cause similar symptoms but IMO has a low probability of being the cause. Check the white with black stripe ignition grounding wire coming from the cut-off switch in the boot. A loose bouncing wire in the boot, when driving, could randomly short the ignition and cause backfires and/or kill the engine.
Ray(64BJ8P1)
steveg
Hi Roger,
Ray(64BJ8P1)
I agree, Ray. A friend troubleshot this problem on another friend's 100M. The car would start, then run gradually worse before quitting. Suggest you disconnect that wire from the distributor.
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
H Tourist Trophy Exhaust on Healey Bj8 Austin Healey 2
J Healey BJ8 anti roll bar bushes Austin Healey 2
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
P Distributor and coil BMW in my Austin Healey BJ8 Austin Healey 10
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
S austin healey bj8 gearbox Austin Healey 3
davidb Austin Healey BJ8 dash pad removal Austin Healey 6
davidb Austin healey BJ8 - convertible top alignment Austin Healey 9
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
R healey bj8 Austin Healey 1
B Healey Bj8 [1964] ignition switch Austin Healey 8
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
