Ignition light lense
  • Thread starter Deleted member 21878
  • Start date
The lense for my ignition light is missing. Anyone know where I can buy one?
Mike Tobin
I made new ones.
Used binder divider tabs - the ones with the clear plastic. Each tab is a different color.
In my drift set there was one the same size as the lens whole. I punched it out of the tab and glued it in with a touch of super glue.
While I was at it I made a blue one for the high beam light.
Yup realized they were both red. I found the one in the bottom of the speedo and made the one for the tach. Great tip above. The look identical.
55modified
I have bought some from English Car Parts. You can get different colors. Triumph used different colors. I have red for oil pressure, Yellow for turn signal and green for high beam
J TR2/3/3A Red ignition light stays on Triumph 7
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
Cappy Ignition Warning Light Austin Healey 6
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
T Ignition warning light remains on and headlights come on Austin Healey 8
longbridgehealey Ignition light Austin Healey 11
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
W Ignition Warning Light Austin Healey 6
F TR2/3/3A Ignition Light On Triumph 33
C changing ignition light bayonette Austin Healey 2
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
L Ignition / Charging light wiring Austin Healey 3
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
trotti Speedo ignition light Austin Healey 12
S MGB Ignition Light and Fuel Pump Won't Quite! MG 5
K TR2/3/3A Oh No! Ignition light on again? Triumph 1
K TR2/3/3A Ignition light on TR3.... Triumph 8
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
M Ignition warning light? Spridgets 14
K TR2/3/3A Red ignition light stays on...TR3? Triumph 6
HAN8L1965 Ignition Light Spridgets 5
I TR6 TR6 ignition light faint - this can't be good Triumph 35
M Perennial topic: ignition light Triumph 9
D Ignition light stays on Triumph 4
bugedd Ignition light on after generator replace Spridgets 13
I Bugeye ignition light still on- help please Spridgets 35
sim 1958 ignition light ? Spridgets 5
7 Ignition light stays on after key removed. Why? Triumph 19
M Ignition warning light Triumph 22
Strapping_Lad Post Alternator conversion: Ignition light Spridgets 5
B Ignition light on MG 5
QuickSilver Ignition Light MG 20
T Ignition light still on, help me please!!!!!!! Triumph 17
M Red dash ignition light glowing very little Spridgets 16
Stewart Ignition light inop MG 10
theleisure Ignition Light Spridgets 2
HAN8L1965 Ignition Light ??? Spridgets 8
glemon Ignition Light on '80 B MG 1
A Ignition light color Austin Healey 6
B EGR and Ignition light Spridgets 0
B T-Series Lucas Ignition / Light Switch MG 2
B TR6 71 TR6 Ignition Light Stays On Triumph 27
vping Ignition light on? MG 7
