tony barnhill said:
QuickSilver said:
Stewart said:
If you get lucky and they have one a 79 ford fiesta autozone part number 13107 with the regulator is completely drop in. The only thing that might get you is the fan and pully from the old one may not fit.
Check the voltage of the battery if its topped off and you don't have to far to go you should have no problem getting back on just the battery alone.
Thanks, it's those two humongous lekky cooling fans that concerns me.
I went ahead and ordered this
on eBay this should finish of my modernization attempts - lol
Hope I don't fry the electrical system.
If you did buy it, you're wasting your money & time - all you probably had was a 30+ year old alternator that finally died....no reason to "modernize - especially with that thing!! & those 2 fans: you want them to work properly.
It is always best, I've learned from experience, to make sure every piece of the system is working corectly & as designed before starting to 'modify' anything....&, I've also learned, it is best to keep everything as it was from the factory unless there's a recognizeable improvement (i.e., removing all the emissions on a late car improves power & gas mileage)....but, a 110 amp alternator?? You're creating DPO problems!
It's always hard to respond to posts such as this that presents a quagmire. I respect your tremendous amount of MG knowledge and I appreciate the time you took to respond.
However I disagree with certain elements of your post.
I always improve on all my British cars I've owned by modernizing the systems as they fail from age. For example, when the starter finally fails I'll use the opportunity to go to the new modern high torque ones.
The money I spent today was well spent and will go towards making a reliable transportation vehicle for me to enjoy.
I'll never pass off any of my cars as a concourse specimen rather automotive expressions of myself. It's a hobby for me not a living.
Thanks for your time, I know you meant well.
