Ignition light color
APM
I've located a tachometer to install in my 3000 MkI. I am replacing the bezel and while I'm at it I notice that the little bead for the ignition light is missing, I was going to try to get a small bead at a craft store, can anyone help me with what color it should be? Many thanks for the help.
GregW
Platinum
It's red
Rob Glasgow
I have seen the blue light on BJ7/8 but never on the earlier models. Years ago when I was working on the tach and speedo from my BT7, the small red plastic disk lens fell out of one of the units. I didn't pay attention to which insturment it came from so I can't say if it was for the ignition or high beams.
My recollection is that the blue high beam lights didn't appear on cars until the late sixties or early seventies. Prior to that the high beams were either white or red. At least that is what I recall.
I will say that almost every gold-faced tach and speedo used on the 100-6 thru Mark 2 I have seen on ebay, is missing the colored lens so it's apparent that they weren't installed very securely.
Dave Russell
Yoda - R.I.P
A new lens can be made by punching out a disc of transparent colored filing folder tab. Trim to size & a spot of glue. Often the original missing disc can be found lying in the bottom of the tach or speedometer housing.
On my BN2 I have a late manufactured replacement speedometer which has what I believe to be the wrong color blue lens.
J TR2/3/3A Red ignition light stays on Triumph 7
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
Cappy Ignition Warning Light Austin Healey 6
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
T Ignition warning light remains on and headlights come on Austin Healey 8
longbridgehealey Ignition light Austin Healey 11
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
W Ignition Warning Light Austin Healey 6
D Ignition light lense Austin Healey 6
F TR2/3/3A Ignition Light On Triumph 33
C changing ignition light bayonette Austin Healey 2
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
L Ignition / Charging light wiring Austin Healey 3
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
trotti Speedo ignition light Austin Healey 12
S MGB Ignition Light and Fuel Pump Won't Quite! MG 5
K TR2/3/3A Oh No! Ignition light on again? Triumph 1
K TR2/3/3A Ignition light on TR3.... Triumph 8
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
M Ignition warning light? Spridgets 14
K TR2/3/3A Red ignition light stays on...TR3? Triumph 6
HAN8L1965 Ignition Light Spridgets 5
I TR6 TR6 ignition light faint - this can't be good Triumph 35
M Perennial topic: ignition light Triumph 9
D Ignition light stays on Triumph 4
bugedd Ignition light on after generator replace Spridgets 13
I Bugeye ignition light still on- help please Spridgets 35
sim 1958 ignition light ? Spridgets 5
7 Ignition light stays on after key removed. Why? Triumph 19
M Ignition warning light Triumph 22
Strapping_Lad Post Alternator conversion: Ignition light Spridgets 5
B Ignition light on MG 5
QuickSilver Ignition Light MG 20
T Ignition light still on, help me please!!!!!!! Triumph 17
M Red dash ignition light glowing very little Spridgets 16
Stewart Ignition light inop MG 10
theleisure Ignition Light Spridgets 2
HAN8L1965 Ignition Light ??? Spridgets 8
glemon Ignition Light on '80 B MG 1
B EGR and Ignition light Spridgets 0
B T-Series Lucas Ignition / Light Switch MG 2
B TR6 71 TR6 Ignition Light Stays On Triumph 27
vping Ignition light on? MG 7
