Ignition Light on '80 B
glemon
I have an 80 B, the ignition light has started to come on when idling even if the idle is over 1000 rpm, doesn't cut out until 0ver 1500 rpm or so, it comes on intermittently, but more lately, I know on the cars with generators this indicatss bad charging (generator/voltage regulator) I feel like a newby with this "new" car with the alternator and other modern features.
Do I have a charging problem? What should I check?
Platinum
First, check belt tension.
After that it's on to the alternator. A check with a meter at the battery terminals for a 13.5~14V output, and a check of the specific gravity in the battery cells.
J TR2/3/3A Red ignition light stays on Triumph 7
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
Cappy Ignition Warning Light Austin Healey 6
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
T Ignition warning light remains on and headlights come on Austin Healey 8
longbridgehealey Ignition light Austin Healey 11
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
W Ignition Warning Light Austin Healey 6
D Ignition light lense Austin Healey 6
F TR2/3/3A Ignition Light On Triumph 33
C changing ignition light bayonette Austin Healey 2
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
L Ignition / Charging light wiring Austin Healey 3
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
trotti Speedo ignition light Austin Healey 12
S MGB Ignition Light and Fuel Pump Won't Quite! MG 5
K TR2/3/3A Oh No! Ignition light on again? Triumph 1
K TR2/3/3A Ignition light on TR3.... Triumph 8
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
M Ignition warning light? Spridgets 14
K TR2/3/3A Red ignition light stays on...TR3? Triumph 6
HAN8L1965 Ignition Light Spridgets 5
I TR6 TR6 ignition light faint - this can't be good Triumph 35
M Perennial topic: ignition light Triumph 9
D Ignition light stays on Triumph 4
bugedd Ignition light on after generator replace Spridgets 13
I Bugeye ignition light still on- help please Spridgets 35
sim 1958 ignition light ? Spridgets 5
7 Ignition light stays on after key removed. Why? Triumph 19
M Ignition warning light Triumph 22
Strapping_Lad Post Alternator conversion: Ignition light Spridgets 5
B Ignition light on MG 5
QuickSilver Ignition Light MG 20
T Ignition light still on, help me please!!!!!!! Triumph 17
M Red dash ignition light glowing very little Spridgets 16
Stewart Ignition light inop MG 10
theleisure Ignition Light Spridgets 2
HAN8L1965 Ignition Light ??? Spridgets 8
A Ignition light color Austin Healey 6
B EGR and Ignition light Spridgets 0
B T-Series Lucas Ignition / Light Switch MG 2
B TR6 71 TR6 Ignition Light Stays On Triumph 27
vping Ignition light on? MG 7
