Ignition light
Hi everyone,
I’ve never had an ignition light on our tachometer. When I removed the tach, I found the expected opening in the bottom, however it looks nothing like the other light mounts behind the instruments. I did find a taped off loose white wire coming across from the ignition switch, and another taped off wire coming out of the harness. Now what?
Thanks
Larry
Oh, it’s a 1957 BN4
steveg
Referring to the wiring diagram - ignition "No Charge Warning Lamp" powered by a white wire from the ignition switch via the starter solenoid; yellow wire from the voltage regulator 'D' terminal.
John Turney
Hi everyone,
If that loose wire coming out of the harness is yellow and coming from the D terminal of the voltage regulator (AKA Control Box), the ignition light connects to it and the white wire. It does not connect to ground.
longbridgehealey
Well, that’s it. Both wires were white, but upon further searching, the wire coming in from the D was yellow, spliced to a white. So my second white was really yelllow. Thanks. No ground?
steveg
John Turney
No ground; the light lights based on the difference in voltage between the white ignition wire and no voltage from the yellow D wire. If the voltage is the same in both wires, the generator is functioning and the light is out.
longbridgehealey
Thanks John, that makes sense. And Steve, talked to Toms Import and will order the diagram. Thanks!
Explains why you can't use an LED for the ignition light; however, I did so for years and it seemed to work (no idea why). I put a bulb back in a couple years ago.
longbridgehealey
Hi all, wiring solved, dash wiring all repaired or replaced as needed, except for the ignition warning light. I cannot source the socket for the light. Talked to Moss and they sent me the light fitting for the gas gauge, which would be like trying to put a cat into a bucket of water. Can anyone tell me a source for this socket?
Thanks!
Larry
steveg
Thanks!
Larry
Did you try British Wiring?
longbridgehealey
No I didn’t, thanks!
J TR2/3/3A Red ignition light stays on Triumph 7
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
Cappy Ignition Warning Light Austin Healey 6
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
T Ignition warning light remains on and headlights come on Austin Healey 8
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
W Ignition Warning Light Austin Healey 6
D Ignition light lense Austin Healey 6
F TR2/3/3A Ignition Light On Triumph 33
C changing ignition light bayonette Austin Healey 2
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
L Ignition / Charging light wiring Austin Healey 3
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
trotti Speedo ignition light Austin Healey 12
S MGB Ignition Light and Fuel Pump Won't Quite! MG 5
K TR2/3/3A Oh No! Ignition light on again? Triumph 1
K TR2/3/3A Ignition light on TR3.... Triumph 8
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
M Ignition warning light? Spridgets 14
K TR2/3/3A Red ignition light stays on...TR3? Triumph 6
HAN8L1965 Ignition Light Spridgets 5
I TR6 TR6 ignition light faint - this can't be good Triumph 35
M Perennial topic: ignition light Triumph 9
D Ignition light stays on Triumph 4
bugedd Ignition light on after generator replace Spridgets 13
I Bugeye ignition light still on- help please Spridgets 35
sim 1958 ignition light ? Spridgets 5
7 Ignition light stays on after key removed. Why? Triumph 19
M Ignition warning light Triumph 22
Strapping_Lad Post Alternator conversion: Ignition light Spridgets 5
B Ignition light on MG 5
QuickSilver Ignition Light MG 20
T Ignition light still on, help me please!!!!!!! Triumph 17
M Red dash ignition light glowing very little Spridgets 16
Stewart Ignition light inop MG 10
theleisure Ignition Light Spridgets 2
HAN8L1965 Ignition Light ??? Spridgets 8
glemon Ignition Light on '80 B MG 1
A Ignition light color Austin Healey 6
B EGR and Ignition light Spridgets 0
B T-Series Lucas Ignition / Light Switch MG 2
B TR6 71 TR6 Ignition Light Stays On Triumph 27
vping Ignition light on? MG 7
