Strapping_Lad
Member
The ignition light stays on after I start the car, there is no battery drain and I am stumped... I check the battery with a meter and it reads about 14.5 volts when idling and just under 13 volts with the car off. The ignition light glows bright in the the "on" position and when I start the car it gets slightly dimmer and stays that way. Any ideas?
I WILL figure this electrical stuff out someday, but it looks like it may take a while.
