TR2/3/3A Rear brake shoe steady post
Chuck Murphy
Hi All,
Can you explain to me the adjustment for the rear brake shoe steady posts on a 1957 TR3? The posts with a felt tip/bush on them. Do you adjust them so the brake shoe just does not touch the brake backing plate? What happens as the felt tip crushes, ages, or wears due to brake shoe movement?
Chuck
TR3driver
Great Pumpkin - R.I.P
They need to be adjusted so the shoes are parallel to the drum (and to each other). For me at least, that meant the shoes were a moderate distance away from touching the back plate.
Wear in those posts caused a slightly low brake pedal and a strange, soft clunk shortly after releasing the brakes. When the brakes were applied, the shoes apparently walked out to meet the drum surface, then fell back against the posts when the brakes were released. Took me a long time to find the clunk, then I noticed the pedal was firmer as well.
C
Chuck Murphy
Thanks Randall,I now realize more about the application of the rear brakes than I thought about before. Very, very interesting and helpful.Chuck
KVH General TR Rear Brake Shoe Orientation Triumph 12
jackq MGC MGA rear brake shoe keeper springs..and Two MGCs MG 2
S Sprite mark 4 rear brake shoe springs Spridgets 4
KVH TR4/4A TR4A Rear Brake Shoe Installation Triumph 7
Luke_Healey Rear brake shoe installation tips? Spridgets 4
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
R TR6 Rear brake wheel cylinder fitment Triumph 5
D Rear Brake Drum Nuts Austin Healey 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G Rear Brake Adjustment Austin Healey 30
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
A AH 3000 rear disc brake conversion Austin Healey 28
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
warwick-steve Rear Brake cylinder connection Austin Healey 12
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets BN6 rear brake pipes Austin Healey 15
nevets stuck rear brake drum Austin Healey 18
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
C Help diagnosing rear brake issues... Austin Healey 20
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
A rear brake drum too tight after rebuild Austin Healey 3
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M suggestions on vendor Rear brake rebuild Spridgets 15
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
K TR2/3/3A Rear brake drum won't go on? Triumph 12
RJS TR4/4A Rear Brake Hose Replacement Triumph 7
R Can't remove rear flexible brake hose Spridgets 5
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
C AH3000 MKIII - Rear Brake Problem Austin Healey 1
P Bugeye rear brake springs??????? Spridgets 5
CJD TR2/3/3A Early Rear Brake Cylinders Triumph 2
