ID a choke cable
tomgt6
I have a dual choke cable the has a screw on thread for the nob. I believe it is for a triumph. I know it doesn't work on the GT6+ or mk3.
Do any of the TRs have a choke cable that is dual with a threaded nob?
NutmegCT
Hi Tom -
When you say "dual" choke cable, do you mean there are actually two cables? Or do you mean there's a cable inside a "spiral" sheath?
Mine has the movable cable inside the sheath.
Tom
T
tomgt6
I have a dual sheath with one knob but two braided cables. They go to a choke but they are about 3 inches to short for the gt6.
I am trying to find a picture but will have to take one.
It is like a GT6 choke cable but shorter and has a threaded pull for the knob.
The longest one is about 41 inches long.
D Choke Cable Length Austin Healey 0
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
F TR2/3/3A Choke Cable Problem Triumph 29
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
E T-Series MG TD choke cable MG 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A Choke cable detent Triumph 4
B TR2/3/3A choke cable attachment Triumph 14
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
KVH TR4/4A Choke Cable TR4A Triumph 5
W New choke cable install Triumph 1
af3683 TR2/3/3A New TR-3 Choke Cable Triumph 7
Tinkerman TR2/3/3A TR3A Choke cable hook up Triumph 3
J TR4/4A TR4 Choke Cable Routing Triumph 4
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
af3683 TR2/3/3A TR3 Choke Cable Triumph 17
bugedd Choke cable repair help Spridgets 3
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
R choke cable Spridgets 6
jsfbond Choke cable [square knob] Triumph 0
UmmYeahOk GT6 Choke Cable for a 67 GT6 Triumph 4
Editor_Reid Needed: Choke Cable for BN2 Austin Healey 0
memphis Choke Cable Austin Healey 1
M stromberg choke cable config. Triumph 8
M stromberg 175 choke cable? Triumph 2
G Which choke cable should I use for euro 1500 carbs Spridgets 8
H Choke Cable Return Austin Healey 14
T Choke cable Triumph 1
Tinkerman TR2/3/3A TR3A Choke Cable Questions Triumph 2
jvandyke choke cable length Spridgets 11
H Throttle cable and choke cable holder MG 3
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
J TR6 75 TR6 choke cable problems Triumph 4
