Choke Cable Connection to Rod Assembly Fork
af3683
Can someone please confirm for me how the choke cable wire connects to the cable clamp pin which goes through the rod assembly fork on a TR3B. Specifically, is the nut on the inside or the outside? Mine is on the outside, however the Moss catalog shows the nut on the inside. I'm not sure which is correct or if it even matters. Thank you.
Art
Geo Hahn
Re: Choke Cable Connection to Rod Assembly Fork
Perhaps this helps...
af3683
af3683
Thanks for the photo, George. Once again it appears as though the nut is on the inside of the cable clamp pin (cotter pin on the outside) which goes through the jet lever and the fork on the forward end of the jet control connecting rod (mixture control rod in photo). I'm going to change mine so it conforms with the photo and the Moss catalog. Also, does anyone know if both jet levers are supposed to be perfectly vertical when the choke is NOT engaged? My forward jet lever points maybe an inch toward the rear which would seem to imply that I'm always driving with a little bit of choke on and too rich a mixture. Any help would be appreciated. Thanks.
TR3driver
Great Pumpkin - R.I.P
vivdownunder
For some reason the front choke lever often points forward of vertical. It may have something to do with the fast idle cam geometry.
You can actually discard the horizontal link to the rear carby altogether.
The car will start perfectly well on just the front choke.
Then you don't have to put a foot on the dash to pull the choke out, and the cable will last longer before the knob breaks off. Probably helps the rear jet seals last a bit longer too.
Viv.
martx-5
I just looked up the <span style="font-weight: bold">average low temperature</span> for Melbourne, and <span style="font-weight: bold">it's 50°F.</span> No wonder you can start it with just one carb choked. :jester:
vivdownunder
Sure Art, we don't have snow like NY, but I've had TR's up in the Alps where it gets down to 25 degrees F. Choking the front carby is just something I've found useful over 5 different 4 pot TR's.
Best regards,
Viv.
martx-5
Actually, I have no trouble pulling out the choke for with both carbs hooked up to it. Careful attention to detail will allow the choke jets to function without massive inputs of muscle on the choke cable. Also, Randall (TR3driver) suggests polishing the jets with toothpaste to make them slide easier. Apparently, replacement jets are not as smooth as originals. I did this, and it definitely helped.
So Viv, maybe after you brush your teeth in the morning, you should go out to the garage with that tube of toothpaste and polish up those jets! :cheers:
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
D Choke Cable Length Austin Healey 0
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
F TR2/3/3A Choke Cable Problem Triumph 29
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
E T-Series MG TD choke cable MG 2
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A Choke cable detent Triumph 4
B TR2/3/3A choke cable attachment Triumph 14
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
KVH TR4/4A Choke Cable TR4A Triumph 5
W New choke cable install Triumph 1
af3683 TR2/3/3A New TR-3 Choke Cable Triumph 7
Tinkerman TR2/3/3A TR3A Choke cable hook up Triumph 3
J TR4/4A TR4 Choke Cable Routing Triumph 4
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
af3683 TR2/3/3A TR3 Choke Cable Triumph 17
bugedd Choke cable repair help Spridgets 3
R choke cable Spridgets 6
jsfbond Choke cable [square knob] Triumph 0
UmmYeahOk GT6 Choke Cable for a 67 GT6 Triumph 4
Editor_Reid Needed: Choke Cable for BN2 Austin Healey 0
memphis Choke Cable Austin Healey 1
M stromberg choke cable config. Triumph 8
M stromberg 175 choke cable? Triumph 2
G Which choke cable should I use for euro 1500 carbs Spridgets 8
T ID a choke cable Triumph 3
H Choke Cable Return Austin Healey 14
T Choke cable Triumph 1
Tinkerman TR2/3/3A TR3A Choke Cable Questions Triumph 2
jvandyke choke cable length Spridgets 11
H Throttle cable and choke cable holder MG 3
J TR6 75 TR6 choke cable problems Triumph 4
