Choke cable repair help
bugedd
It looks like I'm not selling the BE after all, so I am chipping away at little projects. One is the choke cable. I've never had it hooked up due to the outer housing being broken off just at the firewall. I tried to slip some bicycle brake housing over the rest of it to hook it up, but when you push the choke cable back in, it just seperates the housing where they are butted up rather than pushing the choke back in.
So does anyone have a way to replacing the entire length of housing and a way to anchor it at the pull so it doesn't seperate when pushing back in?
bugedd
bugedd
That would be the easy fix. Didn't know that was out there, thanks
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
D Choke Cable Length Austin Healey 0
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
F TR2/3/3A Choke Cable Problem Triumph 29
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
E T-Series MG TD choke cable MG 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A Choke cable detent Triumph 4
B TR2/3/3A choke cable attachment Triumph 14
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
KVH TR4/4A Choke Cable TR4A Triumph 5
W New choke cable install Triumph 1
af3683 TR2/3/3A New TR-3 Choke Cable Triumph 7
Tinkerman TR2/3/3A TR3A Choke cable hook up Triumph 3
J TR4/4A TR4 Choke Cable Routing Triumph 4
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
af3683 TR2/3/3A TR3 Choke Cable Triumph 17
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
R choke cable Spridgets 6
jsfbond Choke cable [square knob] Triumph 0
UmmYeahOk GT6 Choke Cable for a 67 GT6 Triumph 4
Editor_Reid Needed: Choke Cable for BN2 Austin Healey 0
memphis Choke Cable Austin Healey 1
M stromberg choke cable config. Triumph 8
M stromberg 175 choke cable? Triumph 2
G Which choke cable should I use for euro 1500 carbs Spridgets 8
T ID a choke cable Triumph 3
H Choke Cable Return Austin Healey 14
T Choke cable Triumph 1
Tinkerman TR2/3/3A TR3A Choke Cable Questions Triumph 2
jvandyke choke cable length Spridgets 11
H Throttle cable and choke cable holder MG 3
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
J TR6 75 TR6 choke cable problems Triumph 4
