choke cable
rossco
Does anyone know off the top if a right hand drive choke cable will work on my left hand drive bugeye? The original stock #'s are different; maybe length difference?
drooartz
As far as I remember (and I'm not near my books right now to confirm) the choke and starter pulls on the Bugeye were in the same place on RHD and LHD cars -- they were not swapped -- so the cables would be the same.
But this is off the top of my head.
jlaird
You got it Drew.
R
rossco
Thanks, guys. Now. There was no choke cable on the car when I got it. How do I install it? Is there a bracket? The handbook I have isn't very explicit.
jlaird
Is a bracket that goes between the carbs. Look at Moss Catalog page 24 Items 60, 61, 75, 63, 64, 65. The Moss catalog with all the exploded drawings is your friend.
If you do not have a catalog, get one. Meanwhile use the one on line. Caraburetors - Bugeye is the page.
R
rossco
Jack. It's the other working end that I don't know about. I have various reference manuals including the Moss and VB catalogs to research but so far I haven't come across anything that describes how to position the control end of the cable. The repair manual assumes there is one in the car so it pretty much skims over it. Is there a bracket for the control end? A picture would be helpful. Thanks again.
jlaird
You mean the knob end. Just stick the whole thing through the dash and fasten a nut on the back with a washer under it.
Tis so simple I guess no one thought to question it.
D Choke Cable Length Austin Healey 0
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
F TR2/3/3A Choke Cable Problem Triumph 29
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
E T-Series MG TD choke cable MG 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A Choke cable detent Triumph 4
B TR2/3/3A choke cable attachment Triumph 14
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
KVH TR4/4A Choke Cable TR4A Triumph 5
W New choke cable install Triumph 1
af3683 TR2/3/3A New TR-3 Choke Cable Triumph 7
Tinkerman TR2/3/3A TR3A Choke cable hook up Triumph 3
J TR4/4A TR4 Choke Cable Routing Triumph 4
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
af3683 TR2/3/3A TR3 Choke Cable Triumph 17
bugedd Choke cable repair help Spridgets 3
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
jsfbond Choke cable [square knob] Triumph 0
UmmYeahOk GT6 Choke Cable for a 67 GT6 Triumph 4
Editor_Reid Needed: Choke Cable for BN2 Austin Healey 0
memphis Choke Cable Austin Healey 1
M stromberg choke cable config. Triumph 8
M stromberg 175 choke cable? Triumph 2
G Which choke cable should I use for euro 1500 carbs Spridgets 8
T ID a choke cable Triumph 3
H Choke Cable Return Austin Healey 14
T Choke cable Triumph 1
Tinkerman TR2/3/3A TR3A Choke Cable Questions Triumph 2
jvandyke choke cable length Spridgets 11
H Throttle cable and choke cable holder MG 3
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
J TR6 75 TR6 choke cable problems Triumph 4
