jamesrockford
This concerns the solid wire cable to the twin ZS carbs. I already replaced this cable once before. Just recently the choke cable has not been fully closing the front carb cam, although it closes the rear one. Is there some adjustment that can be made to solve this problem, or do I have to fork out $60 to get a new cable. I have been able to put a return spring on the cam of the front carb to make it work, but I like to keep things original if I can. It's hard to believe that a choke cable, can fail that quickly, when it hasn't been used all that much.
After tinkering around with adjustments on the choke, I gave up and put in a return spring, a trick I learned from a Jaguar mechanic who did some work on my TR6 years ago.
