TR6 SU Choke Cables for a TR6
jmayled
I've recently added SU carbs to my 75 TR6, only to find that the sotck Triumph choke cables will not reach the front carb.
Can anyone tell me where I can find a viable alternative?
DNK
J- Doesn't the SU's only use 1 choke cable?
Don
ROADSTR6
If you just choke one carb it should still work fine. Have you tried it?
Dave
Terry_Geiger
At the risk of being shot for treason, I used an MGB choke cable for my dual SU installation. It is long enough to easily attach to the front SU and pull the choke. There should be linkage between the chokes that tie the chokes together so you only have to pull the choke lever on one carb to choke both carbs.
philman
when put twin su's on my tr7 i only ran a choke cable to the front carb and the linkage between the carbs engaged the rear carb. i used one of the "universal" cables available at autozone, etc.
DNK
J- Maybe I didn't understand your question. All the responses have smacked me upside the head. Did you mean the cable that was n ther wont reach the front. I always planned on adopting a TR4 cable to my car. Also been suggested to just cut off 1 of the cables from a 6. If yours don't reach that first carb, new cables are in order.
jmayled
jmayled
Thank you all - I am currently only connecting one of the choke cabkes to the front carb, which seems to work ok, although I would like to be able to use the choke on both carbs.
Does anyone know where I can obtian the linkage that connects the chokes on the SU carbs? (SU HS6)
hondo402000
my choke cable broke on my 6, so I hopped in the 4runner headed up to the bike shop, I purchased 2 brake cables for a bike, got home pulled the whole choke mechanism out of the car, pulled the knob and cables out of the black sleeve, cut the old cables off the metal portion and then drilled a hole in the metal rod and then slipped 2 cables into the hole and them brazed them in with a OXy/acc torch. slipped the cables back into the housing and back into the car and then cut them to lenght, worked perfectly. If you have to put new black housing you might purchase the housing at the bike shop too I would imagine you can carefully pry the old housing out and crimp the new ones in.
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
G How NOT to shorten new choke cables... Triumph 14
jlaird More on choke cables-tip of the day. Spridgets 6
C Choke cables - correct size Austin Healey 20
V Choke cables for tri-carb Austin Healey 5
M Choke Cables Again Austin Healey 4
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
