MGB Help! MGB Baulk rings
mmotors
I rebuilt my 64' MGB gearbox and OD. All went well except 3rd syncro (moss motors replacement baulk rings) doesn't work- grinds when down shifting or shifting up to 3rd at higher RPM.
Just removed the gearbox AGAIN and am exploring. Nothing looks wrong or worn??? Tried testing it with a drill attached at the rear, but it must not be high enough RPM's.
Question- what/ how can I check it?? Very frustrated here.
Thanks, Shawn
BlueMax
What you are experiencing is the cone that the baulk ring slides on has been polish by the old baulk ring preventing the new baulk ring to slow the gear down enough to let the slide hub move on to the gear. I always take 180 grit emery and ruff up the cones so that the new baulk ring has something to grab hold as it slows the gear down enough to slide over the hub. It's the same idea when you hone the cylinders of your engine when you install new piston rings, if you didn’t your rings wouldn’t seat. Scuff the cones real well and that should do the job.
M
mmotors
Thank you, that makes sense. Do the synchronizer balls and springs hold the sychronizer moving with the coupling and in turn appling the pressure between the cone and the baulk ring? If so, could weak springs lessen the pressure applied to the baulk ring?
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
B MGB-GT Need help with MGB GT rattle MG 0
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
R MGB Turn signal help 67 MGB MG 2
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
M MGB My 1980 MGB [Need some help please!] MG 28
S MGB-GT need help on an mgb gt 1975 MG 3
S MGB MGB syncro help MG 10
bcliff MGB MGB w/Isuzu V6 need help MG 1
eschneider MGB MGB Piranha / Newtronics help!!!! MG 6
W MGB-GT MGB Ragtop help MG 10
bighealeysource MGB Help needed from new 65 MGB owner MG 11
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
Scott_Hower MGB Help establishing MGB value... MG 16
kurts100 MGB Can you help verify this is a 1964 MGB MG 12
PAUL161 MGB 70 MGB Dilemma. Questions, Questions! HELP! MG 11
53caddy MGB 1973 MGB help Please MG 67
P MGB 63 MGB Overheating Help!! MG 18
N MGB My MGB Won't Start--Please Help MG 36
PAUL161 MGB HELP! 72 MGB coil springs MG 5
W MGB MGB Emission Control I Need Help Please MG 6
Steve P. MGB-GT Help:'70 MGB-GT running hot MG 4
E MGB help! fuse replacement 77 MGB MG 5
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
M MGB MGB Steering Rack Help MG 1
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
