Let me explain a little bit about the car first. Checking with the previous owner, he told me that he has known this car since 1975. Other than new upholstery and a new exhaust system there have been no changes in the car since then. Other than a dent in the hood and a big dent in the right door where his wife backed in to it with thier other car, it has never been wrecked. With this in mind, here's the questions;
1. The inside mirror is a rod mount. According everything I can read, this mirror was ended in 1967 or 1969. There is no mount for a later style mirror. I'm told that this is the one that came with the car when new. ????
2. I read that 1969 was the last year for the aluminum hood. This car has one and I'm again told that it came with the car when new.
3. The right door has no mirror as it's on the right fender. Is this right?
4. Did the 70 have large nuts or wing knock offs on the wire wheels?
All the numbers on the car are correct for the year. Build date was 2/70. Vin numbers and commission numbers are correct. Could someone give me some info. on these matters?
It also has no sun visors and no mounts for them as it has the early style upper windshield bar. The windshield appears to be original as it is milky all the way around the edge and the rubber trim is mostly rotten and the bolts look like they have never been touched. Help! /ubbthreads/images/graemlins/crazy.gif PJ
