Fellows I need some info on the coil springs on my "B". I'm disassembling the front suspension for an overhaul. I have two questions. 1, What is the 1/3 dia. spacer under the spring for and what location in the pan is it to be placed on reassembly? It fell out when removing the spring from the pan and I haven't a clue as to it's placement. 2nd, What is the blue paint mark down the side of the springs for? It is in the same place on both springs. Haynes does not have the answer for either question! /ubbthreads/images/graemlins/confused.gif
