Good fitting car cover recommendation?
PHulst
Bronze
I have Noah car covers for the Corvettes and like them. I have been searching for a cover for my new 100-6, and virtually all will say that they do not include mirror pockets. Given this, I am not sure how well a custom or fited cover will fit with my front fender mirrors. At least most sites know that there are both 2 and 4 seat cars which require different size covers.
The car stays inside, so I don't need weather protection, just from dust and from people who occasionally walk to close, or Labradors who think they need to fetch the tennis ball that just rolled under the car. :D
Does anyone have a recommendation for a cover that fits well? And does anyone make them with front fender mirror pockets?
Thanks!
HealeyRick
I doubt you'll find a cover with mirror pockets since there was no standard mounting location for them and they were dealer installed. I don't know if there is a company that would tailor one to your individual specs and if so, it would probably be expensive. I like the Covercraft covers and if it's being stored inside, you really don't need them to be as form fitting as an outside cover might nee.
P
PHulst
Bronze
Thanks Rick. Any idea which model or material? Per the photos of the covers some models fit a lot tighter than others.
Healey Nut
Try cover craft .
If they don't have one for a healey they should make one and you could always mark the mirror positions and cut slots in the cover and just have the mirrors poke through the slots . If you know someone handy with a sewing machine you could finish the cut edge around the mirror slots .
I did this with a front end blanket I have for the healey . It fits over the. Whole front end and is great when working under the hood . It's made of similar material to moving company furniture blankets , and has a slot cut so you can open the bonnet and I had my good lady cut and finish a slot for the one fender mirror I have .
PC
These guys make covers from multiple materials for a huge variety of cars and a myriad of options for things like mirror pockets.
They will also make customs for anything. If you're driving a belly tank streamliner and towing a teardrop trailer behind it, they can set you up with covers for both.
https://www.calcarcover.com/
stretchit2
I agree with PC. I had California Custom Car Cover make one for me fit great. They included the pockets for the mirrors and I had a local upholstery shop stitch email up. Great fit super quality product.
Bruce
I have a custom cover from California Custom Car Covers as well. Perfect fit with or without the hood erected. I got the Plushweave Cotton Flannel--perfect for inside the garage and occasional outdoor overnight parking at events. Once I got the cover, I "marked" the locations for the mirror pockets but cutting out the holes, sent the cover back and they put in the pockets at no cost. Had it back in less than a week.
I was pretty sure I got my Healey's Noah cover from Tom's Import Toy Sales https://www.tomsimport.com/new/sitemap.asp but I don't see them listed on their site; you might give them a call...
The one I have, though fitted, is loose enough to cover my mid-wheelwell opening fender mounted mirrors just fine. I do however have the spring-loaded ones, and I turn the heads/arms 90* to the rear before putting the cover on. NOTE THAT my mirrors DO NOT require readjusting when this is done, that's the whole point of them being spring loaded__they pop back to their original settings!
I too have Noah covers for (three) other cars, and they're one of the best available for outside storage (which is to say they're equally suited to indoor use). I also have fitted__skin tight__indoor covers for my 2 M Rdstrs, and they show off the lines of the car beautifully, even though it is covered. The M Coupe has a similar indoor fitted cover, but of a thicker, more padded fabric, so the body details aren't quite as sharp.
AUSMHLY
Any car upholstery shop can modify whatever cover you get. Simply ask them to make cut out where your mirror is and if so desired, make a pouch for the mirror. They'll finish off the edges.
If you don't care about astestics, you can use a pair is scissors, make your own cut out, fold the edge over and sew it by hand.
RickB Lots involved when fitting Bugeye to RB car Spridgets 16
S Spitfire Cyl head coolant hose fitting Triumph 1
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Writer2022 GT6 K+N Filter Fitting Triumph 2
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
A Making an A-series engine stand adaptor fitting Spridgets 2
D TR2/3/3A Windshield frame fitting. Triumph 2
B Fitting the Boot Lid Seal Austin Healey 8
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
edkap2002 TR6 lower radiator hose fitting Triumph 2
DerekJ Fitting a 100-Six grille. Austin Healey 10
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
R TR2/3/3A Fitting windshield Triumph 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
D TR2/3/3A front Apron fitting Triumph 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
ckeithjordan TR2/3/3A Oil Fiter Fitting Frustrations Triumph 13
M Fitting a modern radio Austin Healey 9
TulsaFred Convertible Top Fitting problems Spridgets 29
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
TulsaFred Carpet fitting in the Bugeye Spridgets 3
KVH TR4/4A Fitting New Dash--Problem with Dash Pads Triumph 3
PeterK TR4/4A Fitting TWM manifolds for DCOEs Triumph 2
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
I Bugeye fuel fitting Spridgets 3
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H TR2/3/3A Sway bar fitting Triumph 7
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
DornTRoriginal TR2/3/3A Stone Guard and Fender Fitting Issues Triumph 6
