GT6 K+N Filter Fitting
Writer2022
Hi guys...
So, I bought a pair of K+N filters for my MK3 GT6. When I took the old air filter housing off, it has those long bolts that go through to the carb. However, when I wanted to fit the new K+Ns there are no holes on the outer service of the new filters to slide the long bolts through the carb, only holes on the backplate, and I can't use the long bolts. Have I made an error in buying the wrong filters? Or do I just need to get some shorter bolts?
3798j
Bronze
From your description it sounds like the outer filter covers have no holes. I've got K&N's on my GT6 and you can see in the photo that those long bolts are used to attach them. If yours are different...and it sounds like they are, you will need to use shorter bolts
M TR6 Filter housing assembly? Triumph 7
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
DrEntropy MGB Air filter MG 16
F TR4/4A Replacement air filter for SU HS6 Triumph 6
Simmo MGA OIL FILTER MG 3
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
JPSmit Tonights question - sock filter Restoration & Tools 7
O TR6 Oil filter relocate kit Triumph 12
H 280i oil filter TVR 2
R Oil Filter Removal Austin Healey 1
E MGB Oiling foam air filter MG 3
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
Simmo TR2/3/3A Oil filter Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
D General TR Fuel filter before the pump. Triumph 2
M Cooper's Air Filter on H1 Carbs Spridgets 5
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
F Which Original Oil filter assembly for BN7 Austin Healey 19
tahoe healey Cooper decal on air filter Austin Healey 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
tahoe healey Original Air Filter Maintenance Austin Healey 4
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
D TR2/3/3A Air filter Triumph 11
T Oil filter block plate - really? Austin Healey 13
HighAltitudeTR3 TR2/3/3A Fuel bubbling at glass filter bowl Triumph 4
G General TR Fuel Filter Question Triumph 4
Raymond MGB 1969 oil filter MG 4
D TR4/4A TR4A clogged fuel filter Triumph 13
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
D Oil Filter Bolt Seal Austin Healey 2
C For Sale oil filter adaptor and canister Austin Healey Classifieds 0
T TR6 Spinon Oil Filter Adapter Triumph 3
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
Griz Fuel filter location Austin Healey 28
H Spin-on oil filter for BJ8 Austin Healey 26
D TR4/4A extra long oil filter attachment stud Triumph 9
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
