In college, one of my jobs was running the lube rack at the BMC dealer. It's easiest if you can get under the car, like with a lift. There's one bolt to drop the canister, then we had made a special tool for removing the O ring. Took a small screwdriver, cut off the tip and ground it to a point, bent the end 90 degrees and it was a snap to dig out the old ring.
