GL4 gear oil
Rut
As many people have, I'm searching for some GL4 gear lube for my rear end. I have a 73 model 3.9 and don't know if it makes any difference vs the 4.2 that came in the car. Any suggestions or brand preference?
Thanks, Rut
BlueMax
Currently running a 4:55 gear, but use to run a 4:22. Really doesn't make any difference today being that the molecular bonding is way more sophisticated then what was offered when they printed owners manuals. Running high impact 58404 Redline synthetic 75-140 nice and smooth!! If your running a SLD, I would pick up some AC Delco LSD additive to add to GL4-GL5
drooartz
We've got 3 parts stores in town here, but NAPA was the only one to have GL4 in stock. Can't remember the brand, but it has seemed to work just fine.
tinman58 Off Topic GL4-GL5 gear oil Triumph 6
KVH GL4 Gear Oil Triumph 5
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
B TR6 API GL4/GL5, Recommendations from Valvoline Triumph 3
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
