General Tech Fitting the Pistons and Sleeves--Any TR
KVH
My manual appears to show the pistons with the ring clamp in place being fitted from below, not the top. Is that the correct procedure?
Also, I'm concerned that when I "gently pound" the sleeves into place the pistons will drop down onto the crank--and damage or scratch the journals. Is that a realistic concern?
thx
TR3driver
Great Pumpkin - R.I.P
I've always done it the other way : install the liners in the block first and then install the pistons from the top. Don't know that it makes any real difference, just seems more natural to me (since I learned on engines without removable liners) and gives a convenient way of holding the liners while checking ring gaps and so on. The TR3 manual mentions this as an alternate procedure.
The rings give a good deal of friction; it seems unlikely the pistons would move just from installing the liners. But if you want, you could certainly lay a rag or something on the journals.
Rut
thx
I use rod bolt rubbers to protect the bore and crank...too easy and cheap to use vs the alternative.
Rut
TR3driver
Not sure I understand ... are you saying you install the bolts without the caps and then fit rubbers that go over the head of the bolt?
Geo Hahn
...Also, I'm concerned that when I "gently pound" the sleeves into place the pistons will drop down onto the crank...
I'm confused - when you 'gently pound' the sleeves won't the pistons still be sitting on the workbench. I fitted the pistons from above and only after the sleeves were in.
Or did you mean to gently pound the pistons? And I agree, your usual 'soft, non-fluffy' rag to protect the crank.
TR3driver
TR4 workshop manual says to install the pistons into the liners first, then liners into the block. Page 1-121
KVH
KVH
I know but I'm going to do it your way from the top. Geo I meant that if I followed the Manual I'd be tapping the sleeves into place while the pistons were in, and that seems awkward but Randall is probably right that they probably wouldn't drop down.
CJD
I've never had to pound the sleeves in...only back out. Have you tested the fit yet?
KVH
KVH
If they're protruding above the block more than .005, there's likely a problem. Gently tapping with a rubber dead blow hammer can assure they're seated home. I've only done this twice, so I'm not purporting to be an expert yet.
Rut
I haven't pulled and rebuilt a TR4 engine since 1970 and I was thinking it was like MGB and Sprite engines where the rod bolts need covering as you slide the piston/rod assembly in. I guess the TR4s bolts screw in thru the rod cap into the rod vs from the rod thru the cap. Sorry for the confusion!
Rut
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
T Fitting New Pistons........... Austin Healey 2
S Spitfire Cyl head coolant hose fitting Triumph 1
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Writer2022 GT6 K+N Filter Fitting Triumph 2
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
A Making an A-series engine stand adaptor fitting Spridgets 2
D TR2/3/3A Windshield frame fitting. Triumph 2
B Fitting the Boot Lid Seal Austin Healey 8
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
edkap2002 TR6 lower radiator hose fitting Triumph 2
DerekJ Fitting a 100-Six grille. Austin Healey 10
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
R TR2/3/3A Fitting windshield Triumph 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
D TR2/3/3A front Apron fitting Triumph 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
ckeithjordan TR2/3/3A Oil Fiter Fitting Frustrations Triumph 13
M Fitting a modern radio Austin Healey 9
TulsaFred Convertible Top Fitting problems Spridgets 29
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
TulsaFred Carpet fitting in the Bugeye Spridgets 3
KVH TR4/4A Fitting New Dash--Problem with Dash Pads Triumph 3
PeterK TR4/4A Fitting TWM manifolds for DCOEs Triumph 2
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
I Bugeye fuel fitting Spridgets 3
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H TR2/3/3A Sway bar fitting Triumph 7
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
P Good fitting car cover recommendation? Austin Healey 9
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
