Fitting a Moto Lita Steering Wheel
DerekJ
Hi all
Ive just purchased a Derrington style Moto Lita wheel (very nice quality BTW) I have an adjustable column and wonder if someone can set out for me the procedure for removing the existing wheel.
thanks/ubbthreads/images/graemlins/england.gif
Keoke
Hi Derek,Removing original wheel. 1] Around the base of the wheel's hub are three grub screws-Remove them and put in a safe place. 2} Lift the Bonnet and feel under the bonnet lock for a group of harness connectors and trace them back to the steeing box.Disconnect the connections leaving only bullets on the wire ends. 3} go to the cockpit and remove the horn cancellation assy from the steering wheel, be very careful and if the bullets hang up go under neath the car and feed them into the tube. 4} loosen the steering wheel adjuster. 5} get a Proper sized socket wrench and remove the nut in the center of the steering wheel and the small circlip fitted at the top of the shaft. Wheel will now lift off the shaft.-Cheers---Keoke /ubbthreads/images/graemlins/patriot.gif
DerekJ
DerekJ
Thanks Keoke
Sounds pretty simple, Im sure it won't be when I try it this weekend!
cheers /ubbthreads/images/graemlins/cheers.gif /ubbthreads/images/graemlins/england.gif
GregW
Platinum
Hi Derek, Some people have tied a string to the wires at the steering box up front before pulling everything out. Leave the string in the stator tube and use it to pull the wires back down when reinstalling.
Have Fun,
Greg
shorn
After your new wheel is installed and when pulling the wires back down the stator tube, I found it easier to remove the bullet connectors and then resolder them once the wires were pulled through.
kch
Earlier, when I had some question regarding Moto Lita steering wheels/boss Skipp&Lynne wrote this:
Since my car was undergoing complete restoration I installed the boss and it is secured with the nut on the steering column then installed the trafficator wiring and head, I ran some .032 safety wire through the column to pull the wires back with. By the way some shrink sleeving works wonders on holding the wires togther. Then I installed the wheel and horn button
ron wilson
Your question reminded me that about 20 years ago when I bot my BJ8 one of the first things I did was buy a MOto Lita wheel. The instructions said the first thing to do would be to take the olive nut off the stator tube. being new to British car instructions this drove me nuts for several days trying to figure out what the H they were talking about. But I finally got it done and has worked fine ever since.
Keoke
[ QUOTE ]
Thanks Keoke
[/ QUOTE ]----Yep, you just might pack a small lunch.---Keoke /ubbthreads/images/graemlins/laugh.gif /ubbthreads/images/graemlins/patriot.gif---PS if you happen to run across thet olive thingy don't touch him. /ubbthreads/images/graemlins/laugh.gif
DerekJ Fitting Moto Lita - HELP Austin Healey 6
S Spitfire Cyl head coolant hose fitting Triumph 1
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Writer2022 GT6 K+N Filter Fitting Triumph 2
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
A Making an A-series engine stand adaptor fitting Spridgets 2
D TR2/3/3A Windshield frame fitting. Triumph 2
B Fitting the Boot Lid Seal Austin Healey 8
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
edkap2002 TR6 lower radiator hose fitting Triumph 2
DerekJ Fitting a 100-Six grille. Austin Healey 10
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
R TR2/3/3A Fitting windshield Triumph 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
D TR2/3/3A front Apron fitting Triumph 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
ckeithjordan TR2/3/3A Oil Fiter Fitting Frustrations Triumph 13
M Fitting a modern radio Austin Healey 9
TulsaFred Convertible Top Fitting problems Spridgets 29
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
TulsaFred Carpet fitting in the Bugeye Spridgets 3
KVH TR4/4A Fitting New Dash--Problem with Dash Pads Triumph 3
PeterK TR4/4A Fitting TWM manifolds for DCOEs Triumph 2
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
I Bugeye fuel fitting Spridgets 3
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H TR2/3/3A Sway bar fitting Triumph 7
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
P Good fitting car cover recommendation? Austin Healey 9
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
