Failed State inspection-tie-rod end? Need help
jbuffalo
1978 Mg Midget-just got it running and stopping right. It failed the NY state inspection. The front wheels move side ways moving the tie-rod-one is very loose. The garage was not clear about what to do or how to inspect the steering. After looking it up at home it looks like the tie-rod inner ball joint assembly. How big of a job is this. What parts do I buy. Need help and suggestions.thanks Jim
Jim_Gruber
Sounds like a front end rebuild coming up. More than likely far more than tie rod ends. Yoo are about to receive a multitude of answers.
tosoutherncars
Hi Jim,
If you put it up on jack stands, get under it, and have someone shake the tire at 3 and 9 o'clock, you should be able to see play at either the outer end or the inner end of the tie rod (or both ends!)
Not a bad job... Outers (tie rod ends) just involve splitting the end from the steering arm, unscrewing the existing end and screwing on a new one. Measure / adjust toe-in afterward.
The inners aren't horrible either, disassemble and reassemble. The hardest part will be probably be stretching the new rubber gaiter back onto the rack, which can be a real pain in the... rear end. The inner joint (ball housing) can be tightened / adjusted, see John Twist's video for a quick demo. https://www.youtube.com/watch?v=zQt-u-frkJs
jlaird
Mot a big job at all, couple of hours. Check the Moss Catalog for an exploded view and parts.
See Tony for parts.
JPSmit
not a big job - and not too expensive either
tosoutherncars
As Jim G. says, *if* the front end has been neglected, you may find many other things need replacing as well. Bearings. Shocks. A-arm and trunnion bushings, the threaded pin that connects the A-arm to the kingpin, and the kingpin itself. All of them can and do wear, usually as a result of lack of lubrification. Moss and VB make various kits, but all together the parts can easily add up to $1K.
Do your wheels lean in at the top, when viewed from the front? Do the inner edges of your front tires wear more than the outer edge? Usually a good sign of an impending front-end rebuild.
JPSmit
Duncan is right but take a deep breath - that's a worst case scenario - no single part is difficult - start with the tie rod ends/inners and see where you get from there.
JP
PS I can probably slide down and give you a hand especially if you're available on a weekday - Waterloo is pretty close and my wife can hit DSW shoes
J
jbuffalo
Thanks Guys, especially John-Peter-my wife likes Dsw shoes too much. I went back to the shop-there was a new fellow on the front desk-very new 3 days-everything was confusing. Anyway I brought my Vic Br cat. and Moss and the long time older mechanic found their MG repair book and it went in today for the repair. Jim
JPSmit
great! let us know how it goes
J Failed State inspection-tie rod end..follow up Spridgets 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
T TR2/3/3A Petronix Flame thrower coiled failed after 1-1/2 months Triumph 8
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
S Failed Texas Kooler Fan Austin Healey 8
richberman failed rear brake cylinder... Austin Healey 1
BlueMax Griffin Failed Miserably Spridgets 14
SCguy Wedge My TR8 failed CA smog! Triumph 9
T Failed ignition points? Triumph 27
prb51 Failed Thermostat pics Triumph 3
prb51 Failed sleeved thermostat Triumph 18
regularman Well there's one failed idea Spridgets 20
B Failed Emissions Test - Please Help Austin Healey 21
Z MGB 79 MGB: Failed Emissions... MG 14
RobT Second Failed Ignition Rotor in 100 miles???? Triumph 14
A Emission - FAILED! Spridgets 10
D Top installer recommendations NYC tri-State area Austin Healey 0
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
A General TR Brits by The Sea Photo Album - Harkness State Park - Connecticut Triumph 6
C TR2/3/3A Anyone in Washington State North of Seattle? Triumph 4
angelfj1 General TR Triumph Register of America 2014 Meet - Deer Creek State Park, Ohio Triumph 7
I Off Topic Good auto body welder in Wa state? Triumph 7
drooartz MGB The state of my engine -- need some opinions MG 12
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
BobbyD New OD Controller & Solid State Rheostat Triumph 0
D Trip To State College PA Triumph 6
Gerard Q for Washington State residents Spridgets 30
RickB OT - Peter having State FLL competition today Spridgets 9
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
theleisure PA State Inspection Spridgets 25
danstr6 The State of Iowa is CLOSED! Triumph 20
MadMarx Zandvoort - State of Art GP Triumph 7
M Healey King Pins Reamed in Wa. State? Austin Healey 5
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
RickB Please read and comment - out of state car sale Spridgets 28
2wrench Just a quick Latest on state of affairs Triumph 3
vping Installing a Solid State Fuel Pump MG 7
2wrench State of Affairs, my engine rebuild Triumph 3
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
2wrench Just an Latest on rebuild state of affairs Triumph 8
