    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR2/3/3A electric coolant temp gauge in TR3...
6969ronin6969
Well, this weekend I installed an electric temp gauge in my TR3. I believe it's out of a TR4. That was the sellers claim. The gauge is a Jeager gauge with domed glass.
My original gauge had given out on me some time back, and this was a much less expensive option for now.
Now my issue is, the gauge does start reading, but it only gets up to midway between the bars on the gauge used to indicate cold and normal operating temperatures.
I know the car always ran at normal operating temp before so I will assume all is ok now.
My question is, can I/should I adjust the gauge in any way?
Thanks,
Eric
TR3driver
Great Pumpkin - R.I.P
The TR4 gauge had numbers on the face, not just "cold" and "normal". It can be adjusted, but it doesn't sound to me as though yours needs adjusting. The real question is what does it read just before the engine boils over?
TR4nut
This may take it the other way, but did you install the voltage regulator with the gauge? I believe the gauge runs off 10V, not 12V.
6969ronin6969
Randy,
Good catch, you are correct, my understanding was that it ran off of 10V as well so I did install the regulator.
Randall,
Knock on wood, my engine hasn't been boiling over (that I am aware of) so I don't know the answer to that question.
I'll post a picture of the gauge when I get home this evening.
Thanks,
Eric
6TTR3A
Eric,
Not only is the voltage stabilizer important, but the temp sending unit needs to match the gauge model as well.
As Randall mentioned, that early TR4 gauge was full face with temperature number values (90 185 230) and convex glass. The Smiths Jaeger number on the face is BT 2300/OO (for Fº) If that's what you have, the sending unit for the TR4 that Moss sells is real close. (40 ohms at 185º, 20 ohms at 212º)
FRank
6969ronin6969
Sorry for the delay. Here is an image of the gauge. Let me know what you think it is out of.
I did make sure I got a sensor for a TR4 so that end of it should be good, I think...
Thanks for the feedback.
Eric
TR3driver
There should be some numbers visible on the face (but not in your photo), like BT22nn/nn. Those would help track it down. I've seen that funky pattern of ranges, but I don't recall where. Bugeye, maybe?
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
T ?Changing BE to SU electric fuel pump Spridgets 8
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
KVH TR4/4A Electric Overdrive Lever Switch Triumph 3
mgedit TR2/3/3A Electric Powered TR3 Triumph 8
