Easy overview of rocker geometry
Yep, thats a good study on roller rocker arms, and what he says is dead on, most of the roller rocker set ups, have a stock shaft height, yet they take up more space than a standard rocker, so if you don't shim the pedestals, not only are you losing alot of lift, you rocker arm geomentry is all messed up as well. I did a thread here in the past where we used Titan 1.5 rocker arms on a 1380 engine, and ended up shimming them .125" and gained .030" lift back, I posted pictures of it. I have a pretty wild MGB race engine I just started on, we will be using Titan 1.65 roller rocker arms, I got Sean's shims for them, in both thickness to see what we get.
Aggudabbu
Hap,
You don't happen to have a quick link to that thread or a topic I can search for?
Thanks
No I tried to search for it with no luck, best of my memory it was back in the summer, my and Gundy's buddy Alan was building his 1380, which I had help him with on some component work Anyway Alan wa doing final assembly and had the presence of mind to check lift at the valves, and was astonished at the loss of valve lift he was seeing, sent me a picture showing the rocker arm angle, it going up hill to valve. I told him Sean Brown had just did a study on MGB roller rocker arms, and them having too low of shaft height, and needing shimming at the pedestal to gain back lift, I suggested Alan find some flat washers that all measured the same, somewhere around .125", then put one under each of the rocker pedestals, retorque th head and check the lift again, he called me back and reported to me he had gotten back.030" of his lift, I also then posted his new picutre here with the washers in place, and just looking at it you could see the rocker arm geomentry had greatly improved, I suggested to him, perfecting the pushrod length, or even more shimming might result in yet more, but at that point he was satisfied with his findings. he then ordered some .125" precision ground steel and made himself a set of rocker pedestal shims, later I found out David Anton at APT offered them for sale, and since have stumbled across some in some of the spares I aquired over the years.
In the most simple of terms, most all roller rocker arms offered for our cars are designed at a stock shaft center height, but almost always the roller rocker arm is bigger in size than a stock rocker arm, so they tend take up more space and to go up hill to the valve tip, and this can be corrected by shimming the pedestal.
Theorectical lift, meaning cam lift x rocker arm ratio - valve lash, is just that, theorectical, you'll never get it in most cases, you may get close, but a rocker arm moves in arc, and as we ask it to move more (further downward) in that arc with higher lift cams the rocker ratio will decrease. David Anton and I have talked about this alot, he told me as delivered, that the Keith Dodds 1.5 forged non roller rocker arms come closer to actual advertised ratio than anything he has tested, but the good news is if you want roller rocker arms you can get back your lost lift with pedestal shims, and the Titan bushed shaft 1.5 ratio roller assembly are a good buy for the money.
BlueMax
Hap,
Found the photos depicting the rocker arm geometry. What I did to resolve the problem after a conversation with Hap. I had a few leftover flat ARP hardened washers that I used to put under the rocker stand, I believe they were about .110”to.115” thick, so I slide one under each rocker stand, they fit perfect between the head stud and rocker stud. I torque every thing back and re-adjusted all the valves with their correct valve lash. Then set up the dial indicator to see what I would get. I got an additional .030" lift and the pushrod was where it should be, you can see in the photos what I’m talking about. I knew that I should be some where in the .435 total with the SPVP-3 APT cam. I located some precision ground .125”flat bar stock, proceeded to make the shims out of that. I then set everything back up and check again, I was able to get .430” total lift which was good enough. Threw a photo of the combustion chamber! Thanks again Hap for advice!
BlueMax
Here’s a photo depicting the .125" shims installed, note the rocker geometry. It is now correct were by maximizing the proper rocker arm ratio.
jlaird
Auhhh man, that is too preaty to run.
Gundy and I are hedging bets he may never anyway, he just make a coffee table out of that engine :jester:
Just ribbing my buddy a wee bit :smile:
Gundy
Now ya'll done it. I want some rollers. Do they come in chrome?
I about laughed my head off when I saw those Titans installed
and covered by a perfectly sized clear casserole pan.
Looked just like a glass valve cover.
:devilgrin:
BlueMax looked like a kid at Christmas today with a pile-o-parts
from the Fatherland of the Frogeye.
I'm pushing our pal to make a Nov. deadline.
I ain't taking no bets. I only bet on a sure thing.
:banana:
Roller rockers...drool...
David, those Titan roller rocker are 1.5 ratio, over the stock, 1.25 -1.3 ratio, so they offer additonal valve lift to whatever cam you are using which adds additonal performance, this can be easily done without pulling the engine or even removing the head, so if you want some I get you deal on them. You don't have to worry with vlave clearence issue at the compression ratio and piston to block deck heights street engine are built to, so easy enough to do. The Titan are well built assembly and with the addition of the pedestal shims, which we can now buy from APT (which I already have a set at the shop), we can dial this system in for your car if you decide to do it later on.
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
T General Tech Once again, check the easy stuff Triumph 2
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
H Typical Easy Project takes me 2 hours. Spridgets 5
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
maxwedge5281 easy to get side-tracked! Austin Healey 5
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
4tecdog Headlight relays the easy way Austin Healey 13
CZ_Dave MGB Easy off Oven Cleaner!?!?!?!? Yuppppp! MG 9
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
tomshobby General TR making it easy to lube door hinges Triumph 0
J Nothing is ever easy! Austin Healey 12
max71 MGB The easy way to get the oil pressure relief cap nut back on MG 8
drooartz MGB-GT Easy come, easy go -- my GT is sold MG 2
T Post-War Other Nothing's easy Triumph 6
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
RAC68 EASY Sunday Morning Austin Healey 1
M Tie rod end came apart easy - too easy? Spridgets 6
H two easy questions Austin Healey 14
Boggsy64 MGB Rear end washers easy MG 1
T It's not easy being Green Triumph 7
Cottontop Don't we WISH it was this easy Restoration & Tools 5
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
58Custom Is it easy to convert a '69 US dash to a pre-67? Spridgets 21
Brosky Easy add on fuse block Triumph 7
HealeyRick Restoring a Healey is Easy Austin Healey 7
glemon Quick Easy Removeable Cupholder Triumph 4
Morris If only it were this easy...[ a bit OT ] Spridgets 5
JPSmit Light hit, easy fix Other Cars 4
58Custom Iinstall pre-pillow dash in pillow-dash car? Easy? Spridgets 2
dklawson Solvent Pop - Is There an Easy Fix? Triumph 10
T Why couldn't it be this easy? Triumph 6
H JACK MODIFICATION FOR EASY REAR END LIFTING Triumph 9
A Easy way to remove Cylinder head? Triumph 13
Jim_Gruber Starter goes Click-Oh how easy this car is to fix Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
germanmichel Easy way to move the 3litre engine out of the car? Austin Healey 7
N T-Series Is there an easy way to remove clutch M/C? MG 4
drooartz Bugeye engine removal is easy! Spridgets 8
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
6 Please say it's easy...Dash pad removal Austin Healey 4
Jayrz Oh that was TOO dang easy! Spridgets 8
S Here's an Easy One - Inner Tube Question Triumph 14
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
SCguy TR6 Easy way to install rear gaiter on TR6? Triumph 5
