MGB Easy off Oven Cleaner!?!?!?!? Yuppppp!
CZ_Dave
Received a new customers car, a 1978 MGB as a basket case,
removed everything that was piled up in the interior and took somewhat stock of what was there.
When looking over the car, my previous predecessor completely detailed the engine compartment,
if you call, taking a can of gloss black rattle can paint and painting EVERYTHING,
wiring, and EVERYTHING color coded, and did I say EVERYTHING gloss black.
What do ya do to strip the paint?
My solution, easy off oven cleaner.
Yup! Stuff works, cleaned everything
that was painted , now I can see the color coding on the wiring:highly_amused:
He also painted everything behind the dash that he took out,
with gloss black paint, it works there too.
JPSmit
impressive - can you come do my kitchen? :grin: actually I have used it also - though not that extensively. Scrubbing Bubbles is another go to product - especially for aluminium.
Joe Reed
Thanks for the tip! I've heard of using Easy Off to remove the anodizing from the windshield frame, but not to remove paint like that. I'll have to do that on the wiring in my boot....they're all green :(
Platinum
Half-arsed body shops are to blame.
I ~once~ let a "shop" do the paintwork on one of my Lotus cars... Mitsy and I were coming to Florida for a vacation and to explore employment opportunities, I had stipulated that there should be NO bondo used as the thing was made of "frozen snot" (fiberglass) and should remain so. The other thing was that I wanted all trim and lights removed, no masking of trim. This shop had been doing some work for the Porsche dealer I was working for, that work was done well. When we returned after a couple weeks, he hadn't finished it yet. When I did go to bring it home, he told me he'd had his nephew "help" strip the lights and trim from the thing and the kid had CUT EVERY WIRE about two inches from the Lucar connectors and they hadn't bothered to block off the holes where the lights were in the body. I'd paid him a "deposit" of half of his quoted price, it was immediately explained to him that he was now "Paid in Full" and he could expect NO MORE work from the dealership for his half-baked effort. And later I found that he'd BONDO'd a piece into the hood where I'd asked him to 'glass in a piece after removing the ZS "bump" as I'd fitted a Weber head to the car and the bump was a detraction from the original design. That was pre-Trump: "You're FIRED!" Took me hours of wiping wires with laquer thinner, rags, soldering gun and heat shrink to correct the upscrewed wiring. Easy-Off wouldn't touch the automotive paint in my case.
JPSmit
JPSmit
I was told that to remove anodizing the original formula Easy Off is needed. The new "odor-free" doesn't have the right mojo in it. FWIW
But OTOH your car does smell lemony fresh!
Sarastro
Any strong alkali, not just easy-off, will remove anodizing or aluminum corrosion. It will attack the aluminum, so really should be careful with it. Also, you MUST use gloves with it; keep it off your skin. It might work for degreasing, as long as you're not degreasing aluminum. But there are all kinds of detergents and solvents that are fine for that, and aren't as dangerous to you or the parts.
I had never heard of it used to remove paint, but it's not terribly surprising. The stuff is nasty enough.
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
T General Tech Once again, check the easy stuff Triumph 2
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
H Typical Easy Project takes me 2 hours. Spridgets 5
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
maxwedge5281 easy to get side-tracked! Austin Healey 5
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
4tecdog Headlight relays the easy way Austin Healey 13
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
tomshobby General TR making it easy to lube door hinges Triumph 0
J Nothing is ever easy! Austin Healey 12
max71 MGB The easy way to get the oil pressure relief cap nut back on MG 8
drooartz MGB-GT Easy come, easy go -- my GT is sold MG 2
T Post-War Other Nothing's easy Triumph 6
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
RAC68 EASY Sunday Morning Austin Healey 1
M Tie rod end came apart easy - too easy? Spridgets 6
H two easy questions Austin Healey 14
Boggsy64 MGB Rear end washers easy MG 1
T It's not easy being Green Triumph 7
Cottontop Don't we WISH it was this easy Restoration & Tools 5
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
58Custom Is it easy to convert a '69 US dash to a pre-67? Spridgets 21
Brosky Easy add on fuse block Triumph 7
HealeyRick Restoring a Healey is Easy Austin Healey 7
glemon Quick Easy Removeable Cupholder Triumph 4
Trevor Jessie Easy overview of rocker geometry Spridgets 11
Morris If only it were this easy...[ a bit OT ] Spridgets 5
JPSmit Light hit, easy fix Other Cars 4
58Custom Iinstall pre-pillow dash in pillow-dash car? Easy? Spridgets 2
dklawson Solvent Pop - Is There an Easy Fix? Triumph 10
T Why couldn't it be this easy? Triumph 6
H JACK MODIFICATION FOR EASY REAR END LIFTING Triumph 9
A Easy way to remove Cylinder head? Triumph 13
Jim_Gruber Starter goes Click-Oh how easy this car is to fix Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
germanmichel Easy way to move the 3litre engine out of the car? Austin Healey 7
N T-Series Is there an easy way to remove clutch M/C? MG 4
drooartz Bugeye engine removal is easy! Spridgets 8
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
6 Please say it's easy...Dash pad removal Austin Healey 4
Jayrz Oh that was TOO dang easy! Spridgets 8
S Here's an Easy One - Inner Tube Question Triumph 14
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
SCguy TR6 Easy way to install rear gaiter on TR6? Triumph 5
