Double row timing chains - worth doing on a 1275?
tdskip
For the 1275 which is out of the car at this point, figure access will never be better but not sure it is worth pursuing.
What do you think guys?
2091351
Re: Double row timing chains - worth doing on a 12
<span style="font-weight: bold"><span style="font-size: 14pt">YES</span></span>
with new gears of course!!
Steve
T
tdskip
So what is actually needed for the conversion?
New dual change and sprocket for sure, but anything else?
Tim Hollister
I thought all 1275's came with double row timing chains. With the engine out of the car, I think you ought to pull the timing chain cover and take look. You'll likely be pleasantly surprised.
Tim
I think they all had double row.
Gray_Cat
I believe 1275's all came with double row sprocket/chains as well.
I would be very surprised if they aren't already on the engine, even so, strongly urge replacing them while you have the engine so accesible. You just need order double row sprockets and chain....you might want to check with Mini Mania also as their source may be better qualtiy than Moss or VB.
Roy :cooler:
T
tdskip
I'm obviously learning here, so I'll pull the timing cover and see what lurks behind.
Well that brings up a good, related point.
This engine has good oil pressure, doesn't smoke, and have nice even compression. So I think I'm good for now on bearings etc, but what else should I be doing now since I have good access to her? Seals and other things I should be thinking about?
Thanks!
Sarastro
The only seal I can think of, which is significantly easier to replace with the engine out, is the timing-cover seal around the crank pulley. You'll want to replace the cover gasket too, since you'll be taking the cover off.
I'm of the "if it ain't broke, don't fix it" school, so I think it's wise not to mess with the bearings and such.
I also thought all the 1275s had dual-row chains. When I bought a chain for the 1275 I've been working on, there was only one listed in the catalog.
T
tdskip
Good point Roy!
Too cheap not to do now vs. the pain of pulling everything again.
Thanks for the help guys - appreciate it.
nomad
Had a 10CC 1098 with a single chain that I could turn the crank a quarter turn before the distributor rotor moved!!! Double row for everything you can put them in I would say. KA
PAUL161
Word of advise, while the engine is out, replace the front seal in the tranny! Real cheap, but if you don't, it'll leak later. Duh,
I wonder how I know that!
Sarastro
PAUL161 said:
Word of advise, while the engine is out, replace the front seal in the tranny! Real cheap, but if you don't, it'll leak later. Duh, I wonder how I know that!
Good point. Of course, it will probably leak if you do replace it, but still, keep the faith!
By the way--look on ebay for clutch parts. I often see new clutches for sale there, dirt cheap.
nomad
If you're using the original tranny that has'nt been modified for a seal there's none to replace!!!
Maybe fit one!!! KA
T
tdskip
Thanks guys - I scored a rebuild rib-case that will go in at the same time, but will check the seals etc on that as well. Thanks for the reminder!
Winners Circle sells front tranny covers modified with front seals.
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
kyreb1862 MGB MGB Double Row Timing Chain MG 14
Bruce_B Chain Tensioner on Double Row Chain Spridgets 2
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
steveg At last - inexpensive double crimp tool Restoration & Tools 4
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
E Double posting my healey ad FORUM Navigation Questions 2
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
N DCOE double vs. single choke theory Spridgets 11
TR3driver Double posting FORUM Navigation Questions 0
HealeyRick Elvis's Healey Stunt Double Austin Healey 0
N BJ8 rev counter showing double rev. Austin Healey 13
chrpark Midget '69 Seats- Double Post Headrest, Gd Shape Spridgets 0
drooartz Today's a double anniversary Spridgets 15
AltaKnight Double Trouble Triumph 4
Tinkerman TR2/3/3A TR3 Crank Dog Bolt & Double Wire Clamp Question Triumph 5
B Valve stem seals or double springs? Triumph 5
B Double Bearing Hub Problem Spridgets 10
T TR2/3/3A Double check me on this - TR3a trans & diff fluids Triumph 7
Michael Oritt Double yellow? Racing 10
Banjo Double Jeepin! Other Cars 0
Aldwyn TR2/3/3A TR3... Double Clutch or Syncromesh? Triumph 5
Michael Oritt Double-bearing hub--nut torque Racing 14
EastBoundJoe Double MC piston link Spridgets 3
EastBoundJoe Double line master cylinder problem. Spridgets 11
T TR6 TR6 Spin-on adaptor installation - double check me Triumph 24
tony barnhill DAIMLER Double Decker BUS Other British Cars 13
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
I Double Cylinder Head Gasket Horror ! Austin Healey 10
T Spitfire Replacing single ZS on 1973 Spit with double Triumph 1
G When you rebuild your car double check everything Triumph 7
AUSMHLY double sided foil Thermal Acoustic Blanket Austin Healey 11
K Double Valve Spring for 1500 Spridgets 1
ADIPaul Newbie with SII Daimler Double-Six Vanden Plas Jaguar 8
B Double-clutching Austin Healey 2
78Z Drove a double decker bus Other British Cars 16
S single pole or double pole? Triumph 6
johnrip Wedge TR7 upgraded 4 row radiator Triumph 4
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
