Double-clutching
Brakin80
I've familiar with the term, as well as how one executes a double-clutch. My dad remembers always driving that way back in the day with his '62 tri-carb. What advantage/disadvantage would this have? What does it achieve (if anything) mechanically? Thanks
bradal
Brakin80: Double clutching is a shifting technique used primarily before cars had synchronizers. It is still used to help defeat faulty or missing synchros and also in racing practices. It involves depressing the clutch pedal twice with each shift - the first to initially depart the gear already selected the second after moving the gear lever through neutral, to select the next gear, all while depressing the accelerator pedal to match the speed of the engine with that of the transmission. Remember that the engine drops to idle speed almost immediately, while the transmission continues to be turned by the rear wheels at the same speed. So the object of double clutching is to prevent wear on the clutch and clutch components by matching the speed of the engine with that of the transmission and also to prevent gears from crunching as you select the next speed. I hope this helps some. AL Bradley
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
steveg At last - inexpensive double crimp tool Restoration & Tools 4
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
E Double posting my healey ad FORUM Navigation Questions 2
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
N DCOE double vs. single choke theory Spridgets 11
TR3driver Double posting FORUM Navigation Questions 0
HealeyRick Elvis's Healey Stunt Double Austin Healey 0
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
N BJ8 rev counter showing double rev. Austin Healey 13
chrpark Midget '69 Seats- Double Post Headrest, Gd Shape Spridgets 0
drooartz Today's a double anniversary Spridgets 15
T Double row timing chains - worth doing on a 1275? Spridgets 17
AltaKnight Double Trouble Triumph 4
Tinkerman TR2/3/3A TR3 Crank Dog Bolt & Double Wire Clamp Question Triumph 5
B Valve stem seals or double springs? Triumph 5
kyreb1862 MGB MGB Double Row Timing Chain MG 14
B Double Bearing Hub Problem Spridgets 10
T TR2/3/3A Double check me on this - TR3a trans & diff fluids Triumph 7
Michael Oritt Double yellow? Racing 10
Banjo Double Jeepin! Other Cars 0
Aldwyn TR2/3/3A TR3... Double Clutch or Syncromesh? Triumph 5
Michael Oritt Double-bearing hub--nut torque Racing 14
EastBoundJoe Double MC piston link Spridgets 3
EastBoundJoe Double line master cylinder problem. Spridgets 11
T TR6 TR6 Spin-on adaptor installation - double check me Triumph 24
Bruce_B Chain Tensioner on Double Row Chain Spridgets 2
tony barnhill DAIMLER Double Decker BUS Other British Cars 13
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
I Double Cylinder Head Gasket Horror ! Austin Healey 10
T Spitfire Replacing single ZS on 1973 Spit with double Triumph 1
G When you rebuild your car double check everything Triumph 7
AUSMHLY double sided foil Thermal Acoustic Blanket Austin Healey 11
K Double Valve Spring for 1500 Spridgets 1
ADIPaul Newbie with SII Daimler Double-Six Vanden Plas Jaguar 8
78Z Drove a double decker bus Other British Cars 16
S single pole or double pole? Triumph 6
php411 Spitfire Spitfire Clutch stopped Clutching Triumph 5
Rick O. O/D Clutching Triumph 9
