TR6 Double row timing chain in a 69?
Got_All_4
I was a bit surprised yesterday when I opened up the timing cover and found a double row timing chain. This is in my 69 TR6. were there factory double rows installed in those early years? The inside of the timing cover is also very clean which brings to believe it was changed at some point. Although the tensioner has some wear on it.
David Stong
My TR 250 has a double-row chain. It's No. 7997 out of the 8484 made, so it was made late in '68. My manuals say the double-row was installed in later 250's. So my guess is, they made the switch late in '68, making it reasonable that your '69 6 would have one, too.
Got_All_4
Got_All_4
I was going by my TR250 which had a single row sprocket. I ordered a new double row set up to make sure everything was fresh on the rebuild.
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
T Double row timing chains - worth doing on a 1275? Spridgets 17
kyreb1862 MGB MGB Double Row Timing Chain MG 14
Bruce_B Chain Tensioner on Double Row Chain Spridgets 2
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
steveg At last - inexpensive double crimp tool Restoration & Tools 4
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
E Double posting my healey ad FORUM Navigation Questions 2
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
N DCOE double vs. single choke theory Spridgets 11
TR3driver Double posting FORUM Navigation Questions 0
HealeyRick Elvis's Healey Stunt Double Austin Healey 0
N BJ8 rev counter showing double rev. Austin Healey 13
chrpark Midget '69 Seats- Double Post Headrest, Gd Shape Spridgets 0
drooartz Today's a double anniversary Spridgets 15
AltaKnight Double Trouble Triumph 4
Tinkerman TR2/3/3A TR3 Crank Dog Bolt & Double Wire Clamp Question Triumph 5
B Valve stem seals or double springs? Triumph 5
B Double Bearing Hub Problem Spridgets 10
T TR2/3/3A Double check me on this - TR3a trans & diff fluids Triumph 7
Michael Oritt Double yellow? Racing 10
Banjo Double Jeepin! Other Cars 0
Aldwyn TR2/3/3A TR3... Double Clutch or Syncromesh? Triumph 5
Michael Oritt Double-bearing hub--nut torque Racing 14
EastBoundJoe Double MC piston link Spridgets 3
EastBoundJoe Double line master cylinder problem. Spridgets 11
T TR6 TR6 Spin-on adaptor installation - double check me Triumph 24
tony barnhill DAIMLER Double Decker BUS Other British Cars 13
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
I Double Cylinder Head Gasket Horror ! Austin Healey 10
T Spitfire Replacing single ZS on 1973 Spit with double Triumph 1
G When you rebuild your car double check everything Triumph 7
AUSMHLY double sided foil Thermal Acoustic Blanket Austin Healey 11
K Double Valve Spring for 1500 Spridgets 1
ADIPaul Newbie with SII Daimler Double-Six Vanden Plas Jaguar 8
B Double-clutching Austin Healey 2
78Z Drove a double decker bus Other British Cars 16
S single pole or double pole? Triumph 6
johnrip Wedge TR7 upgraded 4 row radiator Triumph 4
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
