TR6 Door Jam Light Switch Replacement
SherpaPilot
My door jam light switch has failed on my 72 TR6. There doesn't seem to be any of the British car parts guys that sell replacements. Has anyone had any luck replacing their switch with one from another make/model? I know of similar situations where a BMW brake light switch works great in the Triumph (which uses a cheap plastic switch that frequently fails). Any experience in this would be greatly appreciated. Thanks....
dklawson
Our Spitfire had a similar issue with its door light switch. The OEM part and reproductions were NLA except for the occasional (and quite expensive) NOS part on eBay.
You brought up the brake pedal switch. That happens to be what I used in my workaround for the NLA door switch. I bought the generic brake pedal switch from BPNW (MUCH less expensive than bought anywhere else). I made a plastic plate roughly the same size as the flange of the OEM door switch. The plate was tapped 1/2-20 to take the brake pedal switch and had a countersunk through hole for the door jam mounting screw. To mount the switch I had to loosely mount the plate and thread the switch into it from the back, then tighten the flat head screw. It was a fair amount of work but it gave me a working inexpensive solution. I barely had room to get the switch in from the back. I don't know if a TR-6 has similar access.
Sorry... no pictures. I can't even take a picture to send you. We sold the Spitfire last week!
EDIT: I offer this footnote for those wanting to offer other suggestions. I could be wrong, but if the TR-6 is like our Spitfire, the door light switch has two terminals that close to turn the courtesy light on. This is NOT the same as most cars where the door light switch has a single terminal and when the door opens, the switch closes, completing a path to ground via its mounting screw. This switch is basically insulated from ground and has two NC terminals which are "open" when the door is closed.
EDIT2: According to the Advance Auto Wire schematic by Dan Masters, the TR-6 LH and RH door switches are even more different than I imagined. I am leaving my earlier text for those it might benefit but it looks like the TR-6 used a driver's door switch with two pairs of contacts. One set of contacts is for the tunnel courtesy light, the other (like what I described above) is for the ignition key lock lamp.
Link to Advance Auto Wire TR-6 Wiring Diagram
SherpaPilot
SherpaPilot
Thanks for the info Doug. I have the associated lights disabled which is no big deal. I'm only trouble shooting a problem with blowing the associated fuse. I thought this interior circuit may be at fault since the switch is no longer working.
dklawson
Before buying anything, go back to the Advance Auto Wire schematic I posted a link to above. If this is for a '72 TR6 as your signature implies, the schematic shows a single pole switch for the passenger door and a double contact switch for the driver's door. Make sure what you buy is right for the switch that is giving you problems.
SherpaPilot
SherpaPilot
Doug, I just got off the phone with Albert from TRF. We agreed the only switch available is a single pole switch and may not work in my particular car. I seldom drive the car at night anyway but really dislike the idea of unused wires taped inside a door jam. I may try to rebuild this old switch. Thanks for all your advice, it is greatly appreciated.
Don
pdplot
Mine is disconnected. Why have the light go on with opened door while you're working on inside of car? I installed two small lights on sides of gearbox tunnel with a switch on the dash. Now I get light when I want it only. I seldom drive at night with car anyway but it's a good map light.
JerryVV
Call Scott Harper at Team Triumph he may have a used switch. 330-392-7176, Warren Ohio. Call after 1 as he's reduced his hours somewhat.
SherpaPilot TR6 Alternate Door Jam Light Switch Triumph 4
John_Mc TR6 TR6 door jam switch Triumph 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
T Heater Door Spring Austin Healey 1
C Door Latch Mechanism Austin Healey 3
