General Tech Door Glass outer seals installation
Herald63nut
After multiple attempts, I am stymied. Can anyone share a tip, trick, or hint as to how to install the glass outer seal in the door with the clips and the special tool for doing so? So far, pray, swearing, and pints have not resulted in success for me in doing so. Thanks!
ghawk16
I'll be keeping my eye on this thread since I'll be doing this work next weekend. Would be interesting to see the different types of tools used by different individuals and which one was the most efficient.
dklawson
My method may not work for everyone.
Years ago I made a tool from sheet steel about .040" thick, 1" wide, and about 6" long. I bent a "U" profile onto one end. The width and depth of the U was sized to fit the window waist seal clips. I put double-sided tape in the bottom of the U (changed frequently). I press the clips into the U shape and hold the waist seal in place. With the window rolled down I insert the tool into the gap then pull upward to seat the clip so it secures the waist seal to the door edge.
The double-sided tape helps. Without it you will drop a lot of clips into the bottom of the door and lose your religion. I should also mention that I remove the door card before starting. Even with the double-sided tape I still manage to drop some clips.
The tool I made looks like a wide, straight handled version of the one shown in the thread linked below.
https://www.triumphexp.com/phorum/read.php?2,1454923
TomMull
I also made a tool from an old hacksaw blade (you need heat to bend it) but wound up taking the glass, with the lower channel attached, along with the wing or vent window, with frame and all, to do the outer. It maybe took longer but was less frustrating doing it that way. Tool not needed with the glass out.
The glass and vent assembly can then be worked back in, once you get the right combination. Finally the inner seal goes on from the inside with various tools and levers, a screw driver handle for instance, pushing the little clips on.
PITA but I could never get the clips on with a tool. Probably just me, as I think many others have done it.
Either way, make sure you have a magnet to get the dropped clips out of the bottom of the door.
Tom
ghawk16
So I look at these tools with the little notch cut out and I'm assuming that is for the small piece of the clip to go into. Well, if that small piece is in that hole/groove how does it grab the door? If the U is towards the outside of the car wouldn't that hole/groove be towards the inside? And then wouldn't the scrape seal be on the wrong side of the tool? Maybe I'm overthinking it and will make sense when I actually start doing it and make my own tool. However, can the scrape seal be put in before I put my window in and just reach up and push the clips into place?
tomshobby
First I drilled the 1/8" in the seal strip. Then holding the strip in place I used the first holes as guides to drill the 7/64" holes in the door flange. Last I screwed the strip in place. I used the longer drills to avoid hitting the door cap with the drill chuck.
McMasterCarr
Short-Flute Extended-Length Drill Bit
TomMull
If my assumption that you are working on a Herald with a vent window is correct, the window will go in with the scraper on, but you will need to slide the vent assembly and main window in together. At least that's the only way I could make it work. The glass will also go in without the bottom channel, but that doesn't get you much as you will then need to put that channel back on inside the door.
Tom
Tom
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
R TR6 TR6 Door Glass Triumph 5
M TR4/4A TR4 door glass spacer wires. Triumph 1
M TR4/4A Door glass bayley channel clearance measurement. Triumph 4
M TR4/4A Sequence for fitting door glass? Triumph 7
M TR4/4A Door glass assembly help please. Triumph 2
S door glass inner seal Austin Healey 6
T BJ8 door glass replacement Austin Healey 4
maxwedge5281 bj7 door glass and pin questions! Austin Healey 0
B Setting door glass Austin Healey 3
1 Door Glass Seals Spridgets 6
I Door glass Austin Healey 11
TR4nut TR4/4A Anyone have any spare TR4/4A door glass? Triumph 12
I Door Glass Austin Healey 8
T Door glass, bottom channel Spridgets 4
D door glass removal Spridgets 7
jjbunn Door Glass Glazing Strip Triumph 4
M Door Vent Glass Austin Healey 5
Brosky Victory over the "evil door glass gremlins" Triumph 2
P Door Glass came loose... Spridgets 8
AUSMHLY Door Glass Austin Healey 31
Editor_Reid BJ8 Door Glass Austin Healey 6
Jack_Long Need help with door glass MG 2
J door window glass MG 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
