BJ8 Door Glass
Editor_Reid
Platinum
I'd like to ask for your comments about experiences with door glass (the main, large piece; not the "wing window"/"quarter light") for BJ7/BJ8 cars. Is one source's offerings pretty much the same as the next, or are all of the reproductions not-so-hot and it's worth it to search out originals? Moss Motors has them for $138 each -- doesn't seem that bad really when you consider how few they probably sell... but are they good? Thanks.
Keoke
HI Reid if you are talking about aftermarket glass then I think one bin is just as good as the other. On the otherhand,if you are sourcing NOS glass the panels go for about $300.00ea if you can find one.This latter costly approach just insures that the logo on the glasses all match.---Fwiw---Keoke
I cannot say whether they're all the same from the various suppliers but I had to replace both windows on my basket case. I had one original window with a deep scratch in it. Comparing the new (from AHSpares in the UK) with the old showed them to be dimensionally correct and properly shaped with a good fit to the window frame. I've not yet mounted them but I think it should progress without any undue problems due to the glass not being original.
shorn
I replaced my BJ8 driver's door glass with the Moss replacement about a year ago and found the glass to be fine. I actually had a glass shop mount it in the bottom channel piece for me. The fit on the car seems to be as good as the original, which of course doesn't necessarily match up perfectly with the convertible top seal, but that's a Healey.
My original was scratched because the po had put screws in the top rail (arm rest) that were too long. Rolling the window up and down rubbed against the long screws in a couple of spots. I have seen several BJ8's that have the same issue.
John Loftus
BTW, deep scratches in tempered glass are very dangerous. I had the 'deep scratches caused by a long trim screws' on both windows and one morning while filling the car with gas, the passenger window exploded into many small pieces. My wife was sitting in the passenger seat and was covered by the little bits of glass. Luckily she didn't panic or get injured by glass. I've heard of the glass letting go just sitting in the garage or when driving down the interstate. The drivers side also had deep scratches so I purchased a new set from Moss and they fit fine.
Cheers,
John
ron wilson
I also replaced the driver glass on my 66 BJ8 a few years ago.(had the same problem with the original--scratches because of screws being too long.) and replacement I got from Moss fits just fine.(one of the few things I have ordered from them that actually fit.
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
T BJ8 door glass replacement Austin Healey 4
LAW75 BJ8 Door Locks Austin Healey 2
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
wangdango BJ8 door hinge milling? Austin Healey 2
H Door seals BJ8 Austin Healey 15
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
B BJ8 Door hinges Austin Healey 16
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
C BJ8 door strikers keep slippng Austin Healey 7
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
B BJ8 door seal attachement point. Austin Healey 4
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Jeepster BJ8 - Glove box door lock Austin Healey 3
D BJ8 Door Seal Orientation Austin Healey 6
M Bj8 door disassembly Austin Healey 5
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
J BJ8 door latches Austin Healey 3
J BJ8- How is the chrome door top molding installed? Austin Healey 11
bighealeysource door alignment on a BJ8 Austin Healey 1
C BJ8 Door latch question Austin Healey 9
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
P Removing BJ8 Door Panels Austin Healey 21
S BJ8 Door Moulding Installation Austin Healey 6
6 BJ8 Door Latch Austin Healey 3
tahoe healey BJ8 door trim Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
